  • 31 Vote(s) - 2.42 Average
Help! Cannot read HC11F1
I`m trying to read motorola HC11F1 (2F37E) with a china carprog, but without success.
I have connected A10 adaptor like this:
Brown = pin 1
Orange= pin 2
Blue = pin 17
Green = pin 28
Yellow = pin 29
Red = pin 34
and i get attempt 1 2 3 4 5 and null
Maybe i`m doing something wrong,
Pls help
Q: Any pin to pull up?
Usually it's the VDD pin that gets pulled up. I've been trying similar chip, HC11KS2, carprog doesn't list it as a supported type. UPA won't read it, reset high error or device not responding.
I did not tray to read with carprog but for upa an xprog you nead to cut RX,TX,RST
Upa can read it secured
read 2 HC11F1 plcc68 just 1 hour ago using x-prog clone.
For incircuit programming:
1) give +12v (all the pins needed) and gnd to ecu
2) connect to HC11F1 using THESE x-prog schematics like in attachment (should be 7 wires)
3) MOST IMPORTANT: in xprog configuration use THE SAME OSCILLATOR FREQUENCY LIKE IN OSCILLATOR ONBOARD (4mhz,8mhz,16mhz...)
4) select of course HC11F1 in DEVICE SELECTION Wink
I had to do some tries, but this method work ALWAYS, without detaching anything.
bye
Thanks given by: mickye_dj , zhed , djemai , joe1953 , wddn , bubak.f , jcgabbi , P80GTI , Nikola123 , BYECU , bahlawi , byyoyo , GDB
(04-05-2014, 02:24 PM)automf Wrote: read 2 HC11F1 plcc68 just 1 hour ago using x-prog clone.
bye
Hi
Great info 049
I'm trying to read the HC11F1 in a Opel Astra F ECU (red an White plugs)
+12v in my case is that the pins on the red an White plugs?
Example all the red wires? (cant find a schematic for the two plugs).
How do you connect the wires on the small legs?
Thanks a bunch.
Problem Solved, thanks to UPA USB.
Ty all for the help
Thanks given by: besi
may somebody explain how it exactly works?
So isn'T there an easy way to grab the pins from the hc11f1?
Maybe shown in a video, i don'T quit understand :/
(06-23-2014, 02:06 PM)chippy0815 Wrote: may somebody explain how it exactly works?
You need to solder the pins or find a solder point on PCB . thats the easyst way.
Users browsing this thread: wokounek
