109-16-2024, 12:42 PM (This post was last modified: 09-16-2024, 01:12 PM by imark.)
good morning everyone, can someone help me insert a different vin in eeprom in bcm captiva 2009, or is there a script for upa usb ? the eeprom of the original bcm is not readable
thanks
new vin KL1CG26RJ7B119857
BMW programming + All key lost solution Mercedes programming, AMG menu, CARPLAY Range rover Topix + Pathfinder Ford IDS, FJDS, FDRS original license, PATS login GM +Opel online programming Toyota
309-16-2024, 04:05 PM (This post was last modified: 09-16-2024, 04:05 PM by globalcartuning.)
(09-16-2024, 12:42 PM)imark Wrote: good morning everyone, can someone help me insert a different vin in eeprom in bcm captiva 2009, or is there a script for upa usb ? the eeprom of the original bcm is not readable
thanks
you need opcom or tech2win, vin not enoph,you must reset BCM pin and program with car PIN then complet the job
mercedes retrofit,coding,programming,AMG menu,CARPLAY
FORD (remote coding programming) help
opel Coding programming help
JLR services
