have you found the problem? i`m having same issue. thx
[email protected]
Help me in ML350 W164 ESP malfunction
Is it possible that steering rack is replaced? I ask it because i have experience, when customer replaced steering rack whit new used one, but there is two differents types racks on ML.
Rack lenght is little bit different and its cause also esp problems.
It just makes me feel good
12
10-20-2016, 10:50 AM
when he turn, is it at low speed?(around 20-40kmph)
i have encountered this in W211 / W204.
replacing steering rack + switch/sensor fixed it.
no fault codes whatsoever. not sure if the same case as your ML.
(10-20-2016, 10:50 AM)alexjx Wrote: when he turn, is it at low speed?(around 20-40kmph)
yes the steering rack was replaced. but the problem was there before replacing. yes esp comes on at about 30-40 km/h when cornering.
so far i`ve replaced yaw rate sensor, updated esp software, checked on graph wheel speed sensors, tyres are new. no faults on abs esp unit.
14
10-20-2016, 01:03 PM
(10-20-2016, 12:10 PM)med79 Wrote:(10-20-2016, 10:50 AM)alexjx Wrote: when he turn, is it at low speed?(around 20-40kmph)
maybe you want to try with another rack?
that rack that was replaced into it, was it a brand new?
some reconds/used parts do have problems.
15
10-20-2016, 02:57 PM
the problem was before replacing the steering rack. steering rack was replaced because it was leaking. customer says that he tried to turn on the wipers but he moved the selector lever into r while driving. he said that he heard a noise and after that this problem appeared with esp.
16
10-20-2016, 05:46 PM
How about a mechanical problem? Transfer case slipping? Front diff failing? Both are common problems..
18
10-20-2016, 08:48 PM
Probably not..
