28
Thanks Given: 17
Thanks Received: 217 (110 Posts)
204
I had same problem.
In my case I changed ESP control unit. Was installed with wrong part number.
I think on your car somebody changed too, and not by VIN number.
Rule number one: never believe to the customer ))))))
29
Thanks Given: 257
Thanks Received: 237 (129 Posts)
421
50
Just asking:
Is it possible that you mess left and right side wheel speed sensors?
I have one expiriense when one workshop mess wheel speed sensors.
But anyway, connectors should be different.
It just makes me feel good
2,095
Thanks Given: 14574
6,536
46
What's the "road" button?
Are you sure all 4 tires have the same rolling circumference??
alex111
Location OfflineJunior Member
0
Thanks Given: 129
Thanks Received: 15 (12 Posts)
81
15
Have you checked live data reading on wheel sensors , even they were replaced
Thanks Given: 183
Thanks Received: 127 (69 Posts)
203
26
suspension of vehicle okay?? no noises? torsion bar is okay? this is not related to ESP moment control, more towards traction control i believe since it comes on even with ESP turned off. Maybe coil springs have an effect too.. if the car is leaning maybe this caused too.. try and watch the car from behind from another car while someone else drives it
Mercedes-Benz Specialist
