Thanks Given: 24
Thanks Received: 10 (6 Posts)
87
54
hello
i need adjust ecu to the car Opel Astra K 1.5 CDTI ecu delco E45
Thanks Given: 220
Thanks Received: 33 (22 Posts)
500
87
Hi mate,
Any tool to read this ecu?
Thanks a lot
670
Thanks Given: 224
Thanks Received: 1408 (399 Posts)
1,122
193
As I know there is no tools for reas/write this ecu yet. I got 3 ecus for modification but no tools to do that.
36
Thanks Given: 53
Thanks Received: 50 (31 Posts)
181
54
I have a problem with resetting adblue, service required, message. I try everything, no errors, sporadically it jumps out from heater no. 1. The heater test shows 3.7 amps, which means it's working. Everything checked, tests done,, the message is still... do you have any sensible explanation for this situation...
I'm sorry, my english is not the best ...
27
Thanks Given: 40
Thanks Received: 60 (27 Posts)
125
I NEED MDİ AND WİNDOWS 10
AND ME PROBLEM FİX
- ALLDATA EU/USA - HAYNES PRO - MİTHCELL PRO DEMAND - FDRS İDS LİCENSE - FORD ACCOUNT - GM SPS - FİAT EPER -
