I need adjust ECU Opel Astra K 1.5CDTI delco E45 - Printable Version
+---- Forum: GM Group Opel-Vauxhall, Saab, Chevrolet, GM USA, Chrysler Discussions. (https://mhhauto.com/Forum-GM-Group-Opel-Vauxhall-Saab-Chevrolet-GM-USA-Chrysler-Discussions)
+---- Thread: I need adjust ECU Opel Astra K 1.5CDTI delco E45 (/Thread-I-need-adjust-ECU-Opel-Astra-K-1-5CDTI-delco-E45)
I need adjust ECU Opel Astra K 1.5CDTI delco E45 - gabistar - 04-24-2023
hello
i need adjust ecu to the car Opel Astra K 1.5 CDTI ecu delco E45
RE: I need adjust ECU Opel Astra K 1.5CDTI delco E45 - alclot - 07-09-2024
Hi mate,
Any tool to read this ecu?
Thanks a lot
RE: I need adjust ECU Opel Astra K 1.5CDTI delco E45 - Artifact - 07-12-2024
As I know there is no tools for reas/write this ecu yet. I got 3 ecus for modification but no tools to do that.
RE: I need adjust ECU Opel Astra K 1.5CDTI delco E45 - walczaklu - 12-29-2024
I have a problem with resetting adblue, service required, message. I try everything, no errors, sporadically it jumps out from heater no. 1. The heater test shows 3.7 amps, which means it's working. Everything checked, tests done,, the message is still... do you have any sensible explanation for this situation...
RE: I need adjust ECU Opel Astra K 1.5CDTI delco E45 - sazimam - 04-02-2026
(12-29-2024, 01:08 PM)walczaklu Wrote: I have a problem with resetting adblue, service required, message. I try everything, no errors, sporadically it jumps out from heater no. 1. The heater test shows 3.7 amps, which means it's working. Everything checked, tests done,, the message is still... do you have any sensible explanation for this situation...
A per other car manufacturers - they test it on customers that is why so many SW updates exists. The current of the heater seems to be just right but anyways there may be some glitches out there so widening the time window for the DTC trip should solve the problem. Work for manufacturer developers btw.
I have got this one here too, I will test my currents just to compare if you find it helpfull ....
Edit
Heater 1 > 9 Amp
Heater 2 > 5 Amp
RE: I need adjust ECU Opel Astra K 1.5CDTI delco E45 - CarDiagnostc - 04-03-2026
I NEED MDİ AND WİNDOWS 10
AND ME PROBLEM FİX
RE: I need adjust ECU Opel Astra K 1.5CDTI delco E45 - wdariusw - 04-03-2026
If you want to replace E45 ecm - i can do it and program everything remotelly. For modifications E45 not possible yet Smile
