hello I have a problem with a right to a CL500 2003 rear shock, the damper is hydraulic, I've removed as this broken and jumps an error (C1129-001) have looked at prices and new are very expensive and rebuilt too, I found one in a scrap but not if I serve as the reference changed 2 numbers, reference my cushion is a2203209213 and reference cushion scrapping is a2203201813, someone can tell me if this damper helps me to the car, the damper at first glance is the same but as these shock absorbers have an internal sensor is what I do not trust fence is not the same sensor or something ..... what if does not help me where I could find one economic?
[email protected]
I need help with right rear shock
10-26-2016, 12:05 AM
Can someone please tell me if I used the reference a2203201813 for my car, my reference buffer is a2203209213
I don't think you will have problem
Should work
Should work
