I need help with right rear shock - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: I need help with right rear shock (/Thread-I-need-help-with-right-rear-shock) |
I need help with right rear shock - eljisu - 10-25-2016 hello I have a problem with a right to a CL500 2003 rear shock, the damper is hydraulic, I've removed as this broken and jumps an error (C1129-001) have looked at prices and new are very expensive and rebuilt too, I found one in a scrap but not if I serve as the reference changed 2 numbers, reference my cushion is a2203209213 and reference cushion scrapping is a2203201813, someone can tell me if this damper helps me to the car, the damper at first glance is the same but as these shock absorbers have an internal sensor is what I do not trust fence is not the same sensor or something ..... what if does not help me where I could find one economic? RE: I need help with right rear shock - eljisu - 10-26-2016 Can someone please tell me if I used the reference a2203201813 for my car, my reference buffer is a2203209213 RE: I need help with right rear shock - robunicu - 10-26-2016 I don't think you will have problem Should work RE: I need help with right rear shock - eljisu - 10-26-2016 Friend then I can mount the damper on my car? Thank you RE: I need help with right rear shock - robunicu - 10-28-2016 Yes sure |
