Thanks Given: 0
Thanks Received: 0 (0 Posts)
17
I want to change a BCM Module on a Ford Smax from 2008. I have a used BCM Module and need to write immo form ca in module.
With autel I can generate a outcode from the module. Now I need a incode and for this I need a outcode/incode generator.
Can someone help me?
Greetings from germany
443
Thanks Given: 412
Thanks Received: 1620 (1376 Posts)
3,307
37
Post out code I should be able to get u in code for this model year u can dm me also if u want to remember out code changes with each ignition cycle so u have to keep ignition on till u input in code
I like to help, Please Leave Rep +
IF I HELPED YOU....
Autel Ultra S2/IM608S/KM100/ITS600, OBDstar key master plus C/DC706, Key tool plus/max pro/mini, KT200II, IO-Prog, Xentry SDconnect C4, PIWIS 3 VAS6154, KESS/KTAG, Multi-Prog, BIMTOOL PRO, KR55
18
Thanks Given: 48
Thanks Received: 56 (13 Posts)
81
24
06-05-2026, 12:33 AM
(This post was last modified: 06-05-2026, 12:33 AM by pavlo1983.)
Send the code and we'll see what we can do.
