13
Thanks Given: 181
Thanks Received: 35 (30 Posts)
220
85
Hello.
Is possible Full system read and write Gm delco E87? I need modify eeprom virtual for match immobiliser.
I've read that there are problems with write due to the file size.
Has anyone tested this successfully this ECU delco e87.
Best regards
522
Thanks Given: 336
Thanks Received: 1523 (797 Posts)
1,749
125
All good. I did yesterday E87 with KT200, read flash+eeprom.
Also just a hint, you can work on this car/ecu completely via OBD, just in KT200 menu choose FullSystem driver (not need to remove ecu from the car).
If I helped you, press Thanks & Rep+ buttons.
13
Thanks Given: 181
220
85
Did you read as Backup and write as Complete?
You modified eeprom or flash?
Whether the checksum was calculated by kt200?
Thanks for interesting
522
Thanks Given: 336
1,749
125
There is no option for backup/complete, but you have to choose Flash or Eeprom.
Checksum for flash is calculated by kt200, for eeprom no.
522
Thanks Given: 336
1,749
125
I wrote back only Flash (did ST1/DPF/EGR on it), writing took around 20min as I remember.
13
Thanks Given: 181
220
85
I understand what ECU cloning means and that's why it doesn't calculate the checksum of the entire BACKUP.
My question is what to do if I only want to save the eeprom?
I have the option of reading the eeprom itself but not for writing.
Should I modify the eeprom in the entire backup and write the complete one?
