ME17.8.5 with PCMflash
im trying to read / ident a ME17.8.5 from BRP / ROTAX with clone PCMflash1.2.0 and clone SM2 Pro
Selected [71] MEDC17 TC1762.... EEPROM but never got an result. Allways "Failure"
Any ideas? Connection is correct, and cable also.
Maybe bench cable not good. I always use godiag gpt cable. Cheap and reliable, connects to obd from sm2
(06-14-2026, 05:38 AM)g-blaster Wrote: Maybe bench cable not good. I always use godiag gpt cable. Cheap and reliable, connects to obd from sm2
Hi checked with this pinout:
DB25
23 -> GPT1
4  -> GPT2
8 -> CAN-H
9 -> CAN-L
I use L-Line for power switching. Checked with volt meter and it switch.
A little confusing is, that the Module 71 Pinout just says "GPT" and refer 2 pin, no GPT1/2 but i tried both GPT and even same GPT on 2 pins.
https://pcmhelp.ru/data/pcmflash_71.pdf Page 61
Thanks given by: zipoman2011
GPT1 and 2 must be 2 pins, and they are interchangable.
Thanks given by: cdhse
Yes, tested both ways for GPT. But no luck.
9 hours ago
Yesterday, 05:15 PM
06-14-2026, 11:26 PM
