  • 2 Vote(s) - 2.5 Average
Mercedes M113 engine problems
10
Please upload the freeze frame data for the codes
Thanks given by: zdzich
11
Probably you have air leak somewhere as the 2 DTCs says STFT is at maximum +++. Best is smoking the intake system and check for leaks. Or poor fuel pressure.
Thanks given by: Rocinante , zdzich
12
(07-01-2026, 07:51 PM)Botosjeti Wrote: Probably you have air leak somewhere as the 2 DTCs says STFT is at maximum +++. Best is smoking the intake system and check for leaks. Or poor fuel pressure.
Thanks for the suggestion. That was the first thing I did. No air leaks.
sounds like an o-ring/gasket leak to me.
1: the o-ring between manifold and throttle body.
2: the o-ring of the air mass holder. bottom(throttle outlet) middle(the thick rubber between airmass and holder)
3: check your injector o-rings if its not replaced.
If all have been done, have to try the manual but not really recommended way.
get a WD40, with engine running ,spray the intake manifold slowly near surrounding gasket area. injector o-rings.
if engine shake, theres a leak.
since its part load, i think its sucking in air somewhere under pressure. so a smoke test might not be 100% accurate here.
might work, might not.
14
(07-03-2026, 02:03 PM)alexjx Wrote: sounds like an o-ring/gasket leak to me.
Thank you for the suggestions. When I took the manifold out I cleaned the throttle body and replaced the O ring. Also, I replaced the other seals that you have mentioned. No air leaks. Maybe the ECM lost a part of the mapping data or that data is corrupted ? Maybe the ECM needs to be reprogrammed ?
Did the EGR valve you replaced come with the control solenoid?? It could be leaking a small amount of vacuum and keeping the EGR valve open slightly..
Have you checked to make sure the O2 sensor wires aren't crossed left to right??
Try disabling the canister system; I doubt the probes are crossed as @rocinante suggests, since that would take each cylinder bank to the extreme of wealth or poverty, an option for each cylinde4 bank. not both at the limit of correction for rich mixture
Analyze the actual values of any magnitude that affects the mixture to see if, being plausible, It would have an offset that would cause the richness of the mix.
17
Ah, yes, a stuck open purge valve will do that but it's usually accompanied by a fuel tank leak code. Unless it's been disabled.
I'm still waiting to look at the freeze frame data..
18
(07-04-2026, 02:50 AM)Rocinante Wrote: Ah, yes, a stuck open purge valve will do that but it's usually accompanied by a fuel tank leak code. Unless it's been disabled.
Can you please tell me where exactly in Xentry the frame date is ?
