2,095
Thanks Given: 14574
6,536
46
In DAS when looking at the fault codes in the engine control unit, press the print button, it will ask if you want freeze frame data printed, select yes, and hit the print to file box, and name it. It will print as a pdf.
2,095
Thanks Given: 14574
6,536
46
The picture of the lambda on post #5 is proper..
What engine temperature were you taking these screen shots?
The screen shots on this post show the rear O2 sensors are way too active like a faulty catalyst..
I would turn off the air injection and rear O2 monitoring in DAS developer and see what happens..
51
Thanks Given: 277
Thanks Received: 219 (50 Posts)
284
28
24
10-01-2026, 09:02 AM
(This post was last modified: 10-01-2026, 09:06 AM by zdzich.)
September 30, 2026 Update:
I was hoping to take in September the engine and transmission out but I got busy with other projects. Perhaps later in October or November. The car registration ends on December 7th so, I have resolve this problem quickly.
A few days ago I replaced both downstream O2 sensors and the engine was running ok for 95 miles, city and freeway. Economy was good. Then today on the way home the check engine light came back. At the same time the economy got worse. I scanned the engine module with SDS and both codes P0171 and P0174 came back like at the very beginning when the problem begun a few months ago. I checked OBD2 readiness and all monitors were completed except the purge valve, Y58/1. So, on the weekend I'm gonna do more testing and I will post the results.
So, here is the list of all parts I have replaced: all 4 oxygen sensors, EGR valve with gasket and flexible line, all fuel injectors, MAP and MAF sensors, all seals around the throttle body, plastic vacuum lines, intake manifold gaskets, intake manifold was resealed after cleaning inside.
I think I'm running out of ideas. Your feedback will be very appreciated.
0
Thanks Given: 11
Thanks Received: 6 (6 Posts)
25
Hello
If there were no issues with mixture adaptation before the injectors were replaced, I’d suspect the injectors themselves are incorrect or faulty.
One more question: did you reset the mixture adaptations? You might want to try running the "factory settings" or "initial settings" option in the "adaptations" menu.
0
Thanks Given: 11
25
Do the injector part numbers match the VIN?
You’ve probably checked this already, but sometimes a simple oversight leads to strange situations.
Best regards.
