  • 17 Vote(s) - 2.76 Average
Need .cff OM651 CRD2
Hello to all!
Please, i need .cff with
6519027200
6519032121
Thankyou
Don't forget [Image: postbit_thx.gif] and [Image: postbit_reputation.gif]
Hello! It's CRD2? If yes better do SCN update.
(09-24-2016, 01:12 PM)viktor Wrote: Hello! It's CRD2? If yes better do SCN update.
Yes,
that is only a ecu without car, i'm playing around with it.
Or someone have another cff combination who works with
C 250 CDI (S204).
I get a SW-Mismatch now its hard to find the right combinations.
This SW-numbers was flashed in year 2012.
I will try to find your cff today. If I'm not mistaken after you will flash CRD2 you can't start car. First you need to copy scn than flashing
Thanks given by: Vitja
Thank you very mutch.
I don't worry about the car wouldn't start because the ECU is a old one. No one need this ecu again.
With scn you mean the Coding string in HEX format?
Regards
Gesendet von meinem GT-I9505 mit Tapatalk
Yes in hex
Ok I save this
Why do you not use the xentry simulator? you can choose s204 with crd 2 and than you see a right cff combination. I do it with my ic and i find the right combination.
Good idea! I'll test it and hope in my database are the right cff. I will report after this
