Need .cff OM651 CRD2 - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: Need .cff OM651 CRD2 (/Thread-Need-cff-OM651-CRD2) Pages:
Need .cff OM651 CRD2 - Vitja - 09-24-2016 Hello to all! Please, i need .cff with 6519027200 & 6519032121
RE: Need .cff OM651 CRD2 - viktor - 09-24-2016 Hello! It's CRD2? If yes better do SCN update. RE: Need .cff OM651 CRD2 - Vitja - 09-24-2016 (09-24-2016, 01:12 PM)viktor Wrote: Hello! It's CRD2? If yes better do SCN update. Yes, that is only a ecu without car, i'm playing around with it. Or someone have another cff combination who works with C 250 CDI (S204). I get a SW-Mismatch now its hard to find the right combinations. This SW-numbers was flashed in year 2012. RE: Need .cff OM651 CRD2 - viktor - 09-24-2016 I will try to find your cff today. If I'm not mistaken after you will flash CRD2 you can't start car. First you need to copy scn than flashing RE: Need .cff OM651 CRD2 - Vitja - 09-24-2016 Thank you very mutch. I don't worry about the car wouldn't start because the ECU is a old one. No one need this ecu again. With scn you mean the Coding string in HEX format? Regards Gesendet von meinem GT-I9505 mit Tapatalk RE: Need .cff OM651 CRD2 - viktor - 09-24-2016 Yes in hex RE: Need .cff OM651 CRD2 - Vitja - 09-24-2016 Ok I save this Gesendet von meinem GT-I9505 mit Tapatalk RE: Need .cff OM651 CRD2 - CrAckJAck - 09-24-2016 Why do you not use the xentry simulator? you can choose s204 with crd 2 and than you see a right cff combination. I do it with my ic and i find the right combination. RE: Need .cff OM651 CRD2 - Vitja - 09-24-2016 Good idea! I'll test it and hope in my database are the right cff. I will report after this Gesendet von meinem GT-I9505 mit Tapatalk |
