Nissan Qasqai 2.0dci after uploading the flasch, engine doesn't start
Hello
maybe someone will help me. I was programming the Nissan Qasqai 2.0dci 150PS via OBD. After uploading the flasch, the car does not start. The injector codes are rewritten, but there is no synchronization between ECU and BSM.
He constantly throws the error P1614 - Chain of IMMU-KEY
What can I do it best?
Launch x-431 can not do this
what happens when you write ori ?
(05-30-2019, 12:59 AM)kedzior001 Wrote: Hello
tuning really ok and from org?
post both files here.
if are intelligent  key  need start with key into stering lock
What tool you use ?
When returning to the original file is the same situation. The car is with an intelligent key.
Loaded with Kess, I tried to synchronize with Lunch x-431 but it does not go.
Hi M8, seems you locked the ecu, thats there is no comms, need to open and read by bdm programmer to rework files.
Good luck
(05-30-2019, 05:12 PM)jnoroeste Wrote: Hi M8, seems you locked the ecu, thats there is no comms, need to open and read by bdm programmer to rework files.
Good luck
I do not have the original BDM files from this car.
Good luck
I got same problem with kess, rewrite ori by galletto v54 and next inj codes by x431
05-29-2026, 12:39 PM
05-18-2026, 03:18 PM
