Nissan Qasqai 2.0dci after uploading the flasch, engine doesn't start - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: Automotive Tuning. (https://mhhauto.com/Forum-Automotive-Tuning) +--- Thread: Nissan Qasqai 2.0dci after uploading the flasch, engine doesn't start (/Thread-Nissan-Qasqai-2-0dci-after-uploading-the-flasch-engine-doesn-t-start) |
Nissan Qasqai 2.0dci after uploading the flasch, engine doesn't start - kedzior001 - 05-30-2019 Hello maybe someone will help me. I was programming the Nissan Qasqai 2.0dci 150PS via OBD. After uploading the flasch, the car does not start. The injector codes are rewritten, but there is no synchronization between ECU and BSM. He constantly throws the error P1614 - Chain of IMMU-KEY What can I do it best? Launch x-431 can not do this RE: Nissan Qasqai 2.0dci after uploading the flasch, engine doesn't start - vgfiles - 05-30-2019 what happens when you write ori ? RE: Nissan Qasqai 2.0dci after uploading the flasch, engine doesn't start - Tsch325i - 05-30-2019 (05-30-2019, 12:59 AM)kedzior001 Wrote: Hello tuning really ok and from org? post both files here. morfeo - morfeo - 05-30-2019 if are intelligent key need start with key into stering lock RE: Nissan Qasqai 2.0dci after uploading the flasch, engine doesn't start - Cieniu - 05-30-2019 What tool you use ? RE: Nissan Qasqai 2.0dci after uploading the flasch, engine doesn't start - kedzior001 - 05-30-2019 When returning to the original file is the same situation. The car is with an intelligent key. Loaded with Kess, I tried to synchronize with Lunch x-431 but it does not go. RE: Nissan Qasqai 2.0dci after uploading the flasch, engine doesn't start - jnoroeste - 05-30-2019 Hi M8, seems you locked the ecu, thats there is no comms, need to open and read by bdm programmer to rework files. Good luck RE: Nissan Qasqai 2.0dci after uploading the flasch, engine doesn't start - kedzior001 - 05-30-2019 (05-30-2019, 05:12 PM)jnoroeste Wrote: Hi M8, seems you locked the ecu, thats there is no comms, need to open and read by bdm programmer to rework files.I do not have the original BDM files from this car. RE: Nissan Qasqai 2.0dci after uploading the flasch, engine doesn't start - GREGOS - 05-31-2019 (05-30-2019, 09:27 PM)kedzior001 Wrote:(05-30-2019, 05:12 PM)jnoroeste Wrote: Hi M8, seems you locked the ecu, thats there is no comms, need to open and read by bdm programmer to rework files.I do not have the original BDM files from this car. I got same problem with kess, rewrite ori by galletto v54 and next inj codes by x431 |
