(04-09-2020, 10:39 PM)miktek Wrote: how to install please
For version 5.2.6 running 98.0.160....
Download Torrent 1, Torrent 2, Torrent 3 and Key Generator.
Make sure you have Java installed on your computer and it's up-to-date. https://www.java.com/ES/download/
When completed, go to folder "Odis - S 5.2.6 without updates and postsetup"
Install "0.MS_Visual_C++2010 for W10". If you already have it, it'll tell you and don't bother.
If you are using Windows 7, install the appropriate updates in either "0.Prerequirements x64 W7" for 64-bit systems or "x86" for 32-bit systems.
Install ODIS with "1.OffboardDiagSetup-Service_VWMCD_5_2_6-B52_6_0_2"
- Select your diagnostic interface. If you use 6154, select it and click next. If you use PassThru, select it and click next. If you use more than one, select one, click next, go back, select another, click next, etc. If you use an older 6054 interface, there are other instructions that I cannot help you with.
Install will ask you for license file, direct it to the "license.dat" file located in "2.ODIS-S 5.2.6 Patch+License-Full"
Install will ask you for some PostSetup configuration data, direct it to the folder "ODIS-Service_update_5_2_6-EU_20200317_98.0.140" (Torrent 2)
Complete installation.
Once completed, copy "OffboardDiagLauncher.exe" to the ODIS installation folder. (mine is "C:\Program Files (x86)\Offboard_Diagnostic_Information_System_Service")
Launch ODIS... To get past the "Warnings/notes", scroll to bottom and click OK.
At some point, I forget when, ODIS will ask you for registration information. Naturally, this is where the Key Generator is used.
Enter your registration name...
Click "Hardware ID" and paste your HWID from the ODIS registration prompt...
Click "Generate" and copy your registration key to the ODIS registration prompt...
ODIS should prompt you about an update server. Similar to PostSetup configuration data, direct it to the folder "ODIS-Service_update_5_2_6-EU_20200317_98.0.160" (Torrent 3)
It should then begin updating to the 98.0.160 data.
--- IF IT DOES NOT DO THIS ---
Click Admin
Go to Connections tab
Click Mirror Server 2
for Mirror server URL select the 98.0.160 folder (Torrent 3)
Save
In the right pane, expand Extras and click Update. Data should begin updating to 98.0.160
Thanks given by: miktek , oleg71175 , vlad33 , bniko88 , Nacho1.6 , Sergey7084 , Bob the builder , imdk007 , dertechnikfreak , CrossssoveR , Gaintp , jtac , R0undyM0oney , mnawar , Triumph76 , brale , mmihay , KEIN.V , pekemotos , makadam , FLAVIO , stefan3022 , babisxaris , branci2008 , Coco2018 , rudi2 , Alizeirbani , erikosta22 , Mecanodiag75 , mecadriano , RSA1976 , Oxynt3s , JoseSales , skyrimos , Silverdisc , Kamilio2406 , naxnaxnax , nedved59 , olegvg , botafogo , sazimam , gigaby , synapserm76 , Bondiblu , tou2ni , Orionium , westamine , svukov21 , bilel , zuki75 , aekas , jmarijus , MARCOS_ , roundy1986 , mpbrand89 , romiras , harman79 , ToMiBoY , jakim8 , eskilo , akseldz , Massak , Yan77 , mohamed.riachi , fab768 , davidwag , arviza , kosta2302 , Roturbo , wizardstsi , MC2k , pecalin , esse , Vines , iyiannis , NN13 , Hayvosh , josegti , pedropatata , NilsL34 , mourad93390 , kiiker122 , babijoe , matrix2904 , efrairo , duserbl , eLKa , TheAK , nesko0707 , tarcisioz , TechnocarDjerba , Armands91 , greengree , AntanisR , shakehandswithdanger , Bianconi2 , salbutamol , Matacao , Ufkenedy , gerryc89 , Amine13 , R1LEF , djklauss , gaiojulio , jdan , atronchamata , nguyenduyquy , sas24 , smo31 , GGALTSTART , gocuksepetiaydin , Jonathan226 , mastersan , drak999 , mihaiti , Enigma99 , jopega , curretee
