Hi. Car is Opel Antara 2.2d 2010 MT
Problem : I read by OBD with FLEX and after write up car no start.Files tested and its good. I think tool di not correct checksum. I get used other ecu . Read bench and obd backup but from orginal i had only obd backup . I write eep by obd car still no start, and when write flash by obd it stuck on 50% and also killed second ecu.
Now Orginal Ecu I can communicate by obd with diagtool Autel ,Launch etc there read fault live data but cant communicate with tuning tool like kess or Flex obd,bench.
Can someone help with some idea.
I can buy all other ecu full kit with key,dash bcm etc...
Buy other ecu no reason only swap eep physicly,but it was help?
Try reflash by some dealer tool trough obd it will help?
I post obd read by flex .
