Opel Antara DCM3.7AP swap problem(solved) - Printable Version
+---- Forum: GM Group Opel-Vauxhall, Saab, Chevrolet, GM USA, Chrysler Discussions. (https://mhhauto.com/Forum-GM-Group-Opel-Vauxhall-Saab-Chevrolet-GM-USA-Chrysler-Discussions)
+---- Thread: Opel Antara DCM3.7AP swap problem(solved) (/Thread-Opel-Antara-DCM3-7AP-swap-problem-solved)
Opel Antara DCM3.7AP swap problem(solved) - salms3 - 01-21-2024
Hi. Car is Opel Antara 2.2d 2010 MT
Problem : I read by OBD with FLEX and after write up car no start.Files tested and its good. I think tool di not correct checksum. I get used other ecu . Read bench and obd backup but from orginal i had only obd backup . I write eep by obd car still no start, and when write flash by obd it stuck on 50% and also killed second ecu.
Now Orginal Ecu I can communicate by obd with diagtool Autel ,Launch etc there read fault live data but cant communicate with tuning tool like kess or Flex obd,bench.
Can someone help with some idea.
I can buy all other ecu full kit with key,dash bcm etc...
Buy other ecu no reason only swap eep physicly,but it was help?
Try reflash by some dealer tool trough obd it will help?
I post obd read by flex .
RE: Opel Antara DCM3.7AP swap problem - ladadens - 01-21-2024
Magicmorsport support helps for free
Try other tool to read original data
RE: Opel Antara DCM3.7AP swap problem - salms3 - 01-21-2024
(01-21-2024, 02:07 PM)ladadens Wrote: Magicmorsport support helps for free
I think they cant help because Flex now cant connect orginal ecu, kess also cant... ktag i connect other bought ecu and after read checksum fault
To ask for help cost nothing
RE: Opel Antara DCM3.7AP swap problem - Artifact - 01-21-2024
Try on bench or disconnect bcm or power steering if you want to read it on car. This 2 modules most of time can interrupt communications.
RE: Opel Antara DCM3.7AP swap problem - salms3 - 01-22-2024
(01-21-2024, 08:24 PM)Artifact Wrote: Try on bench or disconnect bcm or power steering if you want to read it on car. This 2 modules most of time can interrupt communications.
Bench can’t communicate
RE: Opel Antara DCM3.7AP swap problem - wdariusw - 01-22-2024
Possible adapt new ecu and flash online correct software by VIN code. Need change only ecu, no need change keys or any other modules. If you need this - i can help.
RE: Opel Antara DCM3.7AP swap problem - salms3 - 01-23-2024
Maybe someone can help get pin from ecu dump?
RE: Opel Antara DCM3.7AP swap problem - salms3 - 01-27-2024
Problem solved remote by user wdariusw. Very thankful for his help.
