Thanks Given: 144
Thanks Received: 12 (12 Posts)
439
201
Hello Friends
I need wiring diagram for opel insignia front camera on glass.
VIN W0LZT6EFXJ1020233
180
Thanks Given: 210
Thanks Received: 282 (201 Posts)
482
87
try this if it works out for you.
pass on pm after thx + rep
good luck
If helped hit "+Thanks" and "+Reputation" button .
Have a good day.
Thanks Given: 144
439
201
It is not good wiring diagram for my car. Maybe someone else have insignia diagram for front camera without radar sensor
79
Thanks Given: 273
Thanks Received: 517 (403 Posts)
1,331
Maybe helps to say which insgnia. A or b and year? Not every one can decode vin.
670
Thanks Given: 224
Thanks Received: 1408 (399 Posts)
1,122
193
Is this ok? This is by VIN
Thanks Given: 144
439
201
06-25-2024, 02:18 PM
(This post was last modified: 06-25-2024, 02:22 PM by goontii.)
Yes this is ok. Maybe you know where is K124 Active Safety Control module in this car?
Because bcm and front light reflector module not see front Camera, I have communication errors, and I cant calibrate Camera. Camera is change and wiring is ok.
670
Thanks Given: 224
1,122
193
06-25-2024, 10:14 PM
(This post was last modified: 06-26-2024, 11:29 AM by Artifact.)
(06-25-2024, 02:18 PM)goontii Wrote: Yes this is ok. Maybe you know where is K124 Active Safety Control module in this car?
On the top of battery
Thanks Given: 144
439
201
Top of battery? No module is there. Only main fuse box and Engine control module
