Anyone can seed or send it via other platform ?
[email protected]
Porsche PIWIS / PIDT3 for VAS6154 / J2534 (Unavaiable)
11
01-02-2026, 10:14 PM
For the virtual "D:" drive, you can use a VHD disk on "C:"
diskpart
create vdisk file=C:\PiwisApps.vhd maximum=80000 type=fixed
select vdisk file=C:\PiwisApps.vhd
attach vdisk
create partition primary
format fs=ntfs quick
assign letter=D
exit
diskpart
attach vdisk
assign letter=D
exit
Thanks given by: mecavag
12
01-02-2026, 10:17 PM
(01-02-2026, 10:14 PM)Killz Wrote: For the virtual "D:" drive, you can use a VHD disk on "C:"
diskpart
attach vdisk
assign letter=D
exit
Yes, I've been told.
But not tried it and could not advise on how.
It works with VHD !
But I'ms tuck on voltage test with VNCI 6154A... :/
(01-03-2026, 05:42 PM)Killz Wrote: It works with VHD !
Hi.
Is there a solution to run it with the RED VNCI6154?
Was i helpful? Please click THX and REP...
18
04-09-2026, 12:08 PM
(10-12-2025, 12:09 PM)Magic Wrote: Porsche (PIWIS3) PIDT - Download
This is a complete version of Porsche (PIWIS3) PIDT for professional diagnostics and programming.
Download Size: 42.7GB
Unpacked Size: 57.0GB
Installation Drive: Must be installed on D:\ drive
OS Compatibility: Windows 64-bit systems only
VCI Requirement: VAS6154 or J2534 - Only 1 VCI must be installed
Recommended Pre-Installation Components:
- Microsoft .NET Framework 3.5
- Microsoft .NET Framework 4.8
- Microsoft Visual C++ Runtimes (All-in-One recommended)
- .NET Desktop Runtime 8.0 x64
Installing these components before setup will ensure smooth installation and operation of the software.
Note for C:\ Drive Installations:
If somebody have PIWIS installed on C:\ Reach out to me..
This program must reside on a D:\ drive.
If you wish to install it on your C drive, you can create a directory junction so the software detects it as D:\.
Use the following corrected command in Command Prompt (Run as Administrator) :
Code:mkdir C:\PiwisApps
mklink /J D:\PiwisApps C:\PiwisApps
The D:\ link can point to any small partition, USB stick, or SD card — as long as it is mounted as D:\.
This is a full-featured setup intended for proper workshop or serious enthusiast use.
- VAS6154 Driver (included in package)
Download Link: PM FOR PASSWORD - AFTER THANKS AND REPUTATION
Need help with installation Just reply to the thread.
Use at your own risk. Always back up your system first.
Torrent Download Doesn't Start..!
