Porsche PIWIS / PIDT3 for VAS6154 / J2534 (Unavaiable) - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: Automotive Software. (https://mhhauto.com/Forum-Automotive-Software) +---- Forum: AUTO Software on Torrent (https://mhhauto.com/Forum-AUTO-Software-on-Torrent) +---- Thread: Porsche PIWIS / PIDT3 for VAS6154 / J2534 (Unavaiable) (/Thread-Porsche-PIWIS-PIDT3-for-VAS6154-J2534-Unavaiable) |
Porsche PIWIS / PIDT3 for VAS6154 / J2534 (Unavaiable) - Magic - 10-12-2025 Porsche (PIWIS3) PIDT - Download This is a complete version of Porsche (PIWIS3) PIDT for professional diagnostics and programming. Download Size: 42.7GB Unpacked Size: 57.0GB Installation Drive: Must be installed on D:\ drive OS Compatibility: Windows 64-bit systems only VCI Requirement: VAS6154 or J2534 - Only 1 VCI must be installed Recommended Pre-Installation Components: - Microsoft .NET Framework 3.5 - Microsoft .NET Framework 4.8 - Microsoft Visual C++ Runtimes (All-in-One recommended) - .NET Desktop Runtime 8.0 x64 Installing these components before setup will ensure smooth installation and operation of the software. Note for C:\ Drive Installations: If somebody have PIWIS installed on C:\ Reach out to me.. This program must reside on a D:\ drive. If you wish to install it on your C drive, you can create a directory junction so the software detects it as D:\. Use the following corrected command in Command Prompt (Run as Administrator) : Code: mkdir C:\PiwisAppsThe D:\ link can point to any small partition, USB stick, or SD card — as long as it is mounted as D:\. This is a full-featured setup intended for proper workshop or serious enthusiast use. - VAS6154 Driver (included in package) Download Link: PM FOR PASSWORD - AFTER THANKS AND REPUTATION Need help with installation Just reply to the thread. Use at your own risk. Always back up your system first. PASSWORD: PIDT3VWv1_Colion
Install: Colion RE: Porsche PIWIS / PIDT3 for VAS6154 / J2534 Download - Fdx64 - 10-13-2025 Thanks for sharing. To install Piwis on C: Code: mklink /J D:\PiwisApps C:\PiwisApps You need to create a folder on C:\ PiwisApps The program was installed on the C: drive without any problems. RE: Porsche PIWIS / PIDT3 for VAS6154 / J2534 Download - fantomel - 10-14-2025 Again it seems that no one reads the 1st post of threads. Next smart ass that feels the need for a useless comment and does not know to use the THANKS button or the Rate one will get a warning. RE: Porsche PIWIS / PIDT3 for VAS6154 / J2534 Download - Fdx64 - 10-14-2025 Regarding my comment: When I installed the program on the C: drive and ran the following code: mklink /J D:\PiwisApps C:\PiwisApps Piwis didn't install. I then created a PiwisApps file on the C: drive, and Piwis installed correctly. This is the reason for my comment, and it might help others. RE: Porsche PIWIS / PIDT3 for VAS6154 / J2534 Download - Magic - 10-14-2025 Yes forgot mention need to have folder created. Use the following command in Command Prompt (Run as Administrator): Code: mkdir C:\PiwisAppsRE: Porsche PIWIS / PIDT3 for VAS6154 / J2534 Download - zoli121 - 10-17-2025 I have a question. Does it work with the original VCI or only with a clone? RE: Porsche PIWIS / PIDT3 for VAS6154 / J2534 Download - Magic - 10-17-2025 (10-17-2025, 04:53 AM)zoli121 Wrote: I have a question. Does it work with the original VCI or only with a clone? Genuine VAS6154 or J2534 PassThru VCI. RE: Porsche PIWIS / PIDT3 for VAS6154 / J2534 Download - sezeryaz - 11-09-2025 Hello, Can this be installed on VM ? or is there VM protections ? RE: Porsche PIWIS / PIDT3 for VAS6154 / J2534 Download - vienasisju - 11-12-2025 Thanks for the work. Very easy to install and works great with OEM VAS6154. |
