  • 5 Vote(s) - 4.2 Average
Porsche PIWIS / PIDT3 for VAS6154 / J2534 (Unavaiable)
Porsche (PIWIS3) PIDT - Download
This is a complete version of Porsche (PIWIS3) PIDT for professional diagnostics and programming.
Download Size: 42.7GB
Unpacked Size: 57.0GB
Installation Drive: Must be installed on D:\ drive
OS Compatibility: Windows 64-bit systems only
VCI Requirement: VAS6154 or J2534 - Only 1 VCI must be installed
Recommended Pre-Installation Components:
- Microsoft .NET Framework 3.5
- Microsoft .NET Framework 4.8
- Microsoft Visual C++ Runtimes (All-in-One recommended)
- .NET Desktop Runtime 8.0  x64
Installing these components before setup will ensure smooth installation and operation of the software.
Note for C:\ Drive Installations:
If somebody have PIWIS installed on C:\ Reach out to me..
This program must reside on a D:\ drive.
If you wish to install it on your C drive, you can create a directory junction so the software detects it as D:\.
Use the following corrected command in Command Prompt (Run as Administrator) :
Code:
mkdir C:\PiwisApps
mklink /J D:\PiwisApps C:\PiwisApps
The D:\ link can point to any small partition, USB stick, or SD card — as long as it is mounted as D:\.
This is a full-featured setup intended for proper workshop or serious enthusiast use.
- VAS6154 Driver (included in package)
Download Link: PM FOR PASSWORD - AFTER THANKS AND REPUTATION
Need help with installation Just reply to the thread.
Use at your own risk. Always back up your system first.
PASSWORD: PIDT3VWv1_Colion
Install: Colion
Thanks given by: Alex123222 , dani7.0 , nchafuan , ivica46 , drak999 , ganesh.d.k , Fdx64 , bgauto , oconnell.richard , Oluwole , pdxautoworks , nicu_cuc , ParisCY , avivia55 , Northus , Abu Ameer , cloud9atom , fazooley , zoli121 , vag.obd , hijaycool , mpbrand89 , milanoffracing , warha , Ibrah00 , houbunoudom , Iz3r , evgenijm , SaDEQ , erayayva , Tom-Tech , mkosek , flojd , renzhig , renzhig , astrx , Ckemccoy , harkka24 , pivooo , washinghton , EuroXS4 , bassamsinno , slava.semenovich , SOFTING DEL MAR , vivasc , p0z3r , Kenlaw101 , Ballard , dom92 , hhekimyan , sezeryaz , vienasisju , ChrisS819 , drivenauto , bu.faisal , xginx , nikolani , vw00156 , Igor72 , jack77 , Babaliyev , r0my81 , lucasogorek , danecsongor , ashraf.draz1996 , SeanVV , kiranabcd , zakpro , Kidfodd , mattdj , 7ruswolf , DeamoN420 , seba33 , Quin , Naxa , europhon , natz1991br , Treurentner , ompower , amremurshed , RSRtech , magicyuan , joulinn , Arti_2005 , Killz , premaut , gcesare21 , gksab74 , fenixxpl , C200elias , Snowblue , Russel , ghitab , techm3 , semihovic , gandziak , Kissa , Eclipse.luna , vitaliyko1970 , Gonzalo Moreno , marceldsl , maxxx333 , capricorn2020 , Felixir , deppen_s , Bmwpower530 , Baroti , ANTONIOCECERE , FlashRider , Redlinedesgns , notsotechy , acrawford , 4545 , LA1Z24 , piwisdiag , Supermario , constantine , vankid , Milchgl_s , nosferanosferatuno , rockrapdude , Gab1tzu , zpolice , Diagno19 , The One , bojan.u , miloszekminiu , FürstMD , autoro , Interstate18 , Autodiag2022 , Cavalier3400z , DimonChiptuning , ganker69 , Biju , Alvim , Mr.Nobody , withnote , eliazar26 , iVladimir , ESCO , Baseman , uhhburrito , piston_haus , Vishaldebipersad , 08mhp , markbeville , czar7 , TTWorkshop , madmark , veherion , longnvu , dckr , Vitokarlione , DaBlueOne , Madala , MTW , fafka , arcelik , victor2k , Fat32 , andreaspisko , Thecircuitman , liu.zhi , CMartial777 , carson , iliaspoytsis , foxtwo , nfeel , beppeabarth , erickdnt , eduthuan92 , etolson201 , Zaizius , mafi69 , Hanyolo01 , GTCT2440 , Oscar89 , mclarenax , m17imran , RSKeyService , bob90-6 , Davidpetrisor , bimma328 , Nicolaus , atrefo , Erso204 , rotaxkart , mixmaker , tattun333 , Boxy , Carpov , jarekveghel , Boriska , pablo1981 , makswells1 , mdiag58 , swanouloveu , VIGNESH , fabrice17n , SLR63 , asautosales , Rumper , Musu775 , dogj69 , hammadousahraoui , hansi8181 , ajpm26 , ailanas , ernesto125 , mhhhack122 , unichip , noslen , mecavag , TodTheBeast , anto , NANCY PEREZ 2011 , Supannee , Redalien , truckport , Cm12kv76 , jawier130 , Paul902 , Itchymonkey56 , admin888 , servisjakse , konen , ksvsaransk , chriskain , samerzorba , Altoid , nordcoree
Thanks for sharing.
To install Piwis on C:
Code:
You need to create a folder on C:\
PiwisApps
The program was installed on the C: drive without any problems.
Thanks given by: mecavag , fedosix
Again it seems that no one reads the 1st post of threads. Next smart ass that feels the need for a useless comment and does not know to use the THANKS button or the Rate one will get a warning.
If you like my post and it helped you please press [Image: postbit_thx.gif]&[Image: postbit_reputation.gif]
Regarding my comment: When I installed the program on the C: drive and ran the following code:
Piwis didn't install.
I then created a PiwisApps file on the C: drive, and Piwis installed correctly. This is the reason for my comment, and it might help others.
Thanks given by: NANCY PEREZ 2011
Yes forgot mention need to have folder created.
Use the following command in Command Prompt (Run as Administrator):
Code:
mkdir C:\PiwisApps
Thanks given by: mecavag , Ukri8051
I have a question. Does it work with the original VCI or only with a clone?
(10-17-2025, 04:53 AM)zoli121 Wrote: I have a question. Does it work with the original VCI or only with a clone?
Genuine VAS6154 or J2534 PassThru VCI.
Thanks given by: zoli121
Can this be installed on VM ? or is there VM protections ?
Thanks for the work. Very easy to install and works great with OEM VAS6154.
Thanks given by: Magic
Porshe
06-12-2026, 08:21 PM
07-16-2025, 03:54 AM
