Hi All. Can somebody help me how to coding RLS in w204. There was Light Sensor, but my friend replace it to RLS. I made adaptation of Rain Sensor, Windscreen and Light Sensor. In actual values all fine, but when I turn on front wipers in 1 position, wipers working as usually. Help please!
[email protected]
Rain\Light Sensor adaptation W204 2008
Check CGW and Front Sam coding
Thanks given by: viktor , quhongyu , MBENZTECH , avandgarde
09-19-2013, 11:33 PM
(09-19-2013, 09:34 PM)Rocinante Wrote: Check CGW and Front Sam coding
I made Front Sam coding:-Light Sensor
-Light Sensor Windscreen
-Rain Sensor
-Regenschliessen
-Regenschliessen Aussenorganisation
-Lichtsensor
-Frontwischer (in this coding I don't know where turn on Rain sensor)
-Frontwischer Aussenorganisation
And I don't know where I should check of rain sensor coding in CGW
09-20-2013, 04:54 AM
Hi friends :
---IT is different of W203 ---
1 Use VIN(17 Code) to check SA Code (Data Card) from EPC. (ie. SA 345)
2 Choose DAS Mode ---SAM(FL) --- "Development Data" --- Control Unit Adaptations ... Control Unit Adaptations(Varient Coding) --- Light Sensor Parameters ---
3 According to "EPC " , To choose one of three kinds of it , and you can perform it .
09-23-2013, 09:16 AM
(09-19-2013, 11:33 PM)viktor Wrote:(09-19-2013, 09:34 PM)Rocinante Wrote: Check CGW and Front Sam coding
ThanksI made Front Sam coding:
-Light Sensor
-Rain Sensor
-Regenschliessen
-Lichtsensor
Same as SAM-F coding, make Rain Senzor active in CGW and will work.
MBRetrofit Map Codes, Remote Star3 Coding
Thanks given by: teris , Rocinante , viktor , avandgarde
10-30-2013, 11:11 PM
you need Front Sam+CGW coding:
-Light Sensor
-Rain Sensor
-Regenschliessen
-Lichtsensor
-Make Rain Senzor active in CGW
AND IT WILL WORK!
-Light Sensor
-Rain Sensor
-Regenschliessen
-Lichtsensor
AND IT WILL WORK!
(10-30-2013, 11:11 PM)viktor Wrote: you need Front Sam+CGW coding:
-Light Sensor
-Rain Sensor
-Regenschliessen
-Lichtsensor
AND IT WILL WORK!
thanks for your reply
but i dont kown how to set in CGW yet . can you tell me step to step how to set in CGW unit ? thank you very much
regards
