Thanks Given: 90
Thanks Received: 14 (10 Posts)
94
15
Hi guys,
I change the headlights due to an accident.
The adaption with the very long QR-Code went fine, but the LED is not working (just the headlight is lighting all the time, nothing more).
Do I need to perform a SCN coding additional??
If so, can someone support me with the SCN code?
Thanks!
42
Thanks Given: 248
Thanks Received: 198 (87 Posts)
173
21
10-15-2016, 04:51 PM
if the accident you have installed a new headlight and the new control unit, you will need to make commissioning and enter qrcode.
42
Thanks Given: 132
Thanks Received: 214 (115 Posts)
574
30
Hi
Yes contact me I can code that for you and do SCN.
0
Thanks Given: 7
Thanks Received: 2 (2 Posts)
0
As stated earlier, if you are installing a new control unit with the headlight, you'll need to SCN code and enter the QR code
Thanks Given: 90
94
15
Damn, what are the "engineers" doing?!
As I saw the ~110 alphanumeric signs of the QR-Code I thought, wtf.
Such an effort for just replacing headlights.
I use right know a C3 with 09.2014 version.
I also have the good old 07.2012 version.
Can I try something via dev mode or is the 212 mopf to new?
Thanks Given: 90
94
15
10-17-2016, 11:55 AM
(This post was last modified: 10-22-2016, 07:09 PM by RustyRyan.)
I used vediamo and solved my issue successfully, e.g. transferred the data from HLI_FR212 to HLI_FL212.
Thanks for response.
