S212 MY14 ILS LED SCN coding required? - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: S212 MY14 ILS LED SCN coding required? (/Thread-S212-MY14-ILS-LED-SCN-coding-required) |
S212 MY14 ILS LED SCN coding required? - RustyRyan - 10-15-2016 Hi guys, I change the headlights due to an accident. The adaption with the very long QR-Code went fine, but the LED is not working (just the headlight is lighting all the time, nothing more). Do I need to perform a SCN coding additional?? If so, can someone support me with the SCN code? Thanks! RE: S212 MY14 ILS LED SCN coding required? - IGNASIO88 - 10-15-2016 if the accident you have installed a new headlight and the new control unit, you will need to make commissioning and enter qrcode. RE: S212 MY14 ILS LED SCN coding required? - danrad - 10-15-2016 Hi Yes contact me I can code that for you and do SCN. RE: S212 MY14 ILS LED SCN coding required? - Corleonz - 10-15-2016 vediamo u can make it RE: S212 MY14 ILS LED SCN coding required? - ricecooker713 - 10-15-2016 As stated earlier, if you are installing a new control unit with the headlight, you'll need to SCN code and enter the QR code RE: S212 MY14 ILS LED SCN coding required? - RustyRyan - 10-15-2016 Damn, what are the "engineers" doing?! As I saw the ~110 alphanumeric signs of the QR-Code I thought, wtf. Such an effort for just replacing headlights. I use right know a C3 with 09.2014 version. I also have the good old 07.2012 version. Can I try something via dev mode or is the 212 mopf to new? RE: S212 MY14 ILS LED SCN coding required? - RustyRyan - 10-17-2016 I used vediamo and solved my issue successfully, e.g. transferred the data from HLI_FR212 to HLI_FL212. Thanks for response. |
