  • 5 Vote(s) - 2.2 Average
SBC problem
Hi mates.
Today came a customer with w211 e class. It has SBC problem. Both batteries are new. Voltage supply fine.
DTC is C25D5 Hydraulikfehler: Druckversorgung gestört
DTC is C25D5 hydraulic malfunction: pressure supply troubled
DAS said, i should bleed the brake system ! But in actual values, all parameters are fine. And the DTC is just sometimes. So, i did not bleed the system.
Brake counter is on 373000. I was wondering, i thought after 300000 brakes activation, dtc c249f should come ?!
I think, i have to replace SBC unit ?! What do you think ? Please help !
THX !!!!
I think replace unit
Thanks given by: Jan1980 , sam13
Reset SBC counter ==> Deactivate then reactivate SBC ==> Bleed system
BUT better to replace all with the new SBC coming with A009.......
Best regards.
[Image: mhhsig.gif]
Thanks given by: Rocinante , hardlynormal , Jan1980 , vasileM
(02-06-2017, 12:26 AM)webmaster Wrote: Reset SBC counter ==> Deactivate then reactivate SBC ==> Bleed system
Best regards.
how do you reset the counter? with developer mode?
best regards
Hi. Thank you for the answers. I deactivated the brake system and checked the calipers and brake pads. Then, i bleed the system. Trouble code is gone. I did not reset the counter because there was no trouble code c249f or anything.
