PXL213 multibeam headlight need help
I need help with coding Multibeam headlights on a W213 fl model. I’ve been performing the coding by copying the text from the QR code and entering it into Xentry (offline). The right-hand headlight is showing error B178356: "Control unit 'LED driving lights actuation module' has a malfunction. An incorrect or incompatible configuration was detected." It also shows B178392: "Control unit 'LED driving lights actuation module' has a malfunction. The function or the instruction is faulty."
The left headlight shows error C151E31: "The left front level sensor has a malfunction." I need to check this, as a control arm was recently replaced—it’s possible something wasn’t plugged back in, though this sensor error doesn’t appear anywhere else i need to check it.The left headlight also shows the same B178356 error: "Control unit 'LED driving lights actuation module' has a malfunction. An incorrect or incompatible configuration was detected."
This after coding in Xentry, I went into Monaco 8.16 and unlocked the EZS security level 3b (the other options were 37 and 39). Then, in PXL213, I ran the following sequence:
1. Extended Start
2. Delay
3. DJ_Unlock Access Special Functions
4. Delay
5. Sicherheitsrelevante Parameter Start (Safety-relevant parameters start)
6. Delay
7. HardReset Reset
8. Delay
9. Extended Start
10. Delay
11. DJ_Unlock Access Special Functions
12. Delay
13. Sicherheitsrelevante Parameter Start
14. Delay
15. HardReset Reset
Unfortunately, this didn’t help; the same error codes remain. I’m also wondering which "Extended Start" option I should be using in Monaco—there are two: "10.03 Extended Start" and "10.83 Extended Start" (the latter has an icon showing an arrow and a monitor).
Which one is the correct choice? Could someone please help me with these headlights?
retrofit or just change
DTS9.04.016
MB software
206223coding
M6+ Pro,C3
DS,Citroen,Peugeot Online
Lexus online//DST010
(Yesterday, 06:27 PM)job Wrote: retrofit or just change
Just change
(Yesterday, 06:08 PM)inelyo Wrote: Hi,
1. Extended Start
2. Delay
4. Delay
6. Delay
7. HardReset Reset
8. Delay
9. Extended Start
10. Delay
12. Delay
14. Delay
15. HardReset Reset
First you have to code it, only after coding is correct you can do the routine
MBRetrofit Map Codes, Remote Star3 Coding
Users browsing this thread: inelyo, jysi, 1 Guest(s)
