PXL213 multibeam headlight need help - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: PXL213 multibeam headlight need help (/Thread-PXL213-multibeam-headlight-need-help) |
PXL213 multibeam headlight need help - inelyo - 11-21-2026 Hi, I need help with coding Multibeam headlights on a W213 fl model. I’ve been performing the coding by copying the text from the QR code and entering it into Xentry (offline). The right-hand headlight is showing error B178356: "Control unit 'LED driving lights actuation module' has a malfunction. An incorrect or incompatible configuration was detected." It also shows B178392: "Control unit 'LED driving lights actuation module' has a malfunction. The function or the instruction is faulty." The left headlight shows error C151E31: "The left front level sensor has a malfunction." I need to check this, as a control arm was recently replaced—it’s possible something wasn’t plugged back in, though this sensor error doesn’t appear anywhere else i need to check it.The left headlight also shows the same B178356 error: "Control unit 'LED driving lights actuation module' has a malfunction. An incorrect or incompatible configuration was detected." This after coding in Xentry, I went into Monaco 8.16 and unlocked the EZS security level 3b (the other options were 37 and 39). Then, in PXL213, I ran the following sequence: 1. Extended Start 2. Delay 3. DJ_Unlock Access Special Functions 4. Delay 5. Sicherheitsrelevante Parameter Start (Safety-relevant parameters start) 6. Delay 7. HardReset Reset 8. Delay 9. Extended Start 10. Delay 11. DJ_Unlock Access Special Functions 12. Delay 13. Sicherheitsrelevante Parameter Start 14. Delay 15. HardReset Reset Unfortunately, this didn’t help; the same error codes remain. I’m also wondering which "Extended Start" option I should be using in Monaco—there are two: "10.03 Extended Start" and "10.83 Extended Start" (the latter has an icon showing an arrow and a monitor). Which one is the correct choice? Could someone please help me with these headlights? RE: PXL213 multibeam headlight need help - job - 11-21-2026 retrofit or just change RE: PXL213 multibeam headlight need help - inelyo - 11-21-2026 (Yesterday, 06:27 PM)job Wrote: retrofit or just change Just change RE: PXL213 multibeam headlight need help - trigital - 11-22-2026 (Yesterday, 06:08 PM)inelyo Wrote: Hi,First you have to code it, only after coding is correct you can do the routine |
