893
Thanks Given: 580
Thanks Received: 1617 (203 Posts)
1,107
253
12-13-2016, 01:11 AM
Anyone experience lan failure on SD CONNECT C4?
I have no communication at all.
I have tested port on laptop to make sure it is not faulty, it works fine using internet lan cable.
I changed C4 green lan cable - still no comms
I changed LAN port on the C4 - still no comms
I changed ribbon cable in C4 - still no comms.
So must be some component on the small board which has failed. Anyone know which one it is?
764
Thanks Given: 188
Thanks Received: 1110 (96 Posts)
268
20
Does wifi work?
REVERSE ENGINEERINGÂ | SOFTWARE ENGINEER
893
Thanks Given: 580
1,107
253
This is the strangest problem.
So
PC1 - C4 mux it doesn't detect on this computer. I have checked network connections and even changed network driver. It will NOT connect. I tried it on another PC (PC2 below) and it worked fine!. I then tested network port using LAN internet cable, internet worked fine. So i assumed laptop software is corrupted. So i reformat it freshly and put software back on. Again NO connection to the C4 MUX!. But internet works fine!.
PC2 - (Same software as above but different laptop) - C4 mux detects perfect fine. No problems at all.
WTF?
232
Thanks Given: 1304
Thanks Received: 3751 (1595 Posts)
2,351
11
You do not mention but aren't you using the mux in adhoc mode (direct connection via the Road24h network)? Your internet connection should not work if the network adapter is correctly configured for the mux, it should have a fixed IP address while your internet connection likely works on automatic IP.
232
Thanks Given: 1304
2,351
11
You could have mentioned your IP address batch files. Now you could have mentioned IP addresses on the mux and the laptop but I'm sure they are fine, you seem to know these details well.
Is it a clone mux? Clones should work with a standard LAN cable, genuine tools need a crossover cable (the green one).
