SD C4 LAN PROBLEM - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: SD C4 LAN PROBLEM (/Thread-SD-C4-LAN-PROBLEM) |
SD C4 LAN PROBLEM - j4g3d - 12-13-2016 Anyone experience lan failure on SD CONNECT C4? I have no communication at all. I have tested port on laptop to make sure it is not faulty, it works fine using internet lan cable. I changed C4 green lan cable - still no comms I changed LAN port on the C4 - still no comms I changed ribbon cable in C4 - still no comms. So must be some component on the small board which has failed. Anyone know which one it is? Thanks RE: SD C4 LAN PROBLEM - fabek - 12-13-2016 Does wifi work? RE: SD C4 LAN PROBLEM - j4g3d - 12-13-2016 (12-13-2016, 01:21 AM)fabek Wrote: Does wifi work?No because need the lan to set it. Anyway, i have since put this c4 onto another software version and it works. So it seems the software has become corrupted!. RE: SD C4 LAN PROBLEM - j4g3d - 12-13-2016 This is the strangest problem. So PC1 - C4 mux it doesn't detect on this computer. I have checked network connections and even changed network driver. It will NOT connect. I tried it on another PC (PC2 below) and it worked fine!. I then tested network port using LAN internet cable, internet worked fine. So i assumed laptop software is corrupted. So i reformat it freshly and put software back on. Again NO connection to the C4 MUX!. But internet works fine!. PC2 - (Same software as above but different laptop) - C4 mux detects perfect fine. No problems at all. WTF? RE: SD C4 LAN PROBLEM - DBmhh - 12-13-2016 You do not mention but aren't you using the mux in adhoc mode (direct connection via the Road24h network)? Your internet connection should not work if the network adapter is correctly configured for the mux, it should have a fixed IP address while your internet connection likely works on automatic IP. RE: SD C4 LAN PROBLEM - j4g3d - 12-13-2016 (12-13-2016, 11:27 PM)DBmhh Wrote: You do not mention but aren't you using the mux in adhoc mode (direct connection via the Road24h network)? Your internet connection should not work if the network adapter is correctly configured for the mux, it should have a fixed IP address while your internet connection likely works on automatic IP. Yes system is set up ad-hoc so now wireless works fine. Internet only works when i use batch files i made to erase IP and set to automatic DHCP. I of course, re-set the correct static IP back with another batch file i made so the lan cable should work again. But it does not. The mux just will not connect via LAN on this laptop. Green mux cable is CAT6?. My internet cable CAT5 works fine though as i say. So i find it so odd. Maybe the port no longer likes CAT 6 cables. Never ever heard of this before. But that is the only possible reasons why its not working?. Everything else works fine on another laptop, using the same software. But this doesn't solve the problem because the laptop which it isn't working with is my friends, and i am trying to sort it for him. RE: SD C4 LAN PROBLEM - DBmhh - 12-14-2016 You could have mentioned your IP address batch files. Now you could have mentioned IP addresses on the mux and the laptop but I'm sure they are fine, you seem to know these details well. Is it a clone mux? Clones should work with a standard LAN cable, genuine tools need a crossover cable (the green one). RE: SD C4 LAN PROBLEM - j4g3d - 12-15-2016 (12-14-2016, 12:19 AM)DBmhh Wrote: You could have mentioned your IP address batch files. Now you could have mentioned IP addresses on the mux and the laptop but I'm sure they are fine, you seem to know these details well. I just left it as it is, working fine with wifi. I suspect the lan port stop liking the green cable, which i think is cat6. My internet lan cable is cat5 and works fine in the same laptop. It was a clone C4 btw and i don't think regular cat5 cable works on it, because in the past i actually bought some cat6 patch/crossover cable and it works fine on these mux's. |
