3,178
Thanks Given: 7612
1,696
53
11-17-2016, 04:54 PM
(This post was last modified: 11-17-2016, 04:56 PM by pesona.)
check pin 8 on the vehicle's obd2 if there is a cable or not.
Thanks Given: 78
Thanks Received: 16 (11 Posts)
163
46
Thank you very much Pesona for your answer.
If other diagnostic equpiment is working fine where else the problem can be?
Regards.
229
Thanks Given: 1492
Thanks Received: 1209 (393 Posts)
629
19
11-17-2016, 06:23 PM
(This post was last modified: 11-17-2016, 06:23 PM by HestonDiag.)
Different diagnostic tools may work in slightly different ways, but for W906 before 2013 facelift, Mr. Pesona's advise is the best place to start.
If you are sceptical about that theory, connect your mux to bench power supply and try to connect to W906. If you enter any values for random values for region, fuel type, model type and mileage then try to perform quick test, you will see it will ask you to turn on ignition. Now give power to pin 8 and you will see your computer and multiplexer now believes ignition is on and will try to scan modules.
Thanks Given: 78
163
46
Just to be sure.
If Sprinter from 2010 year connects right I can assume that it might be the vehicle problem rather than the C4 problem, yes?
Thank you guys for your advices.
