SD C4 Sprinter 2007 "turn on ignition" problem. - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: SD C4 Sprinter 2007 "turn on ignition" problem. (/Thread-SD-C4-Sprinter-2007-turn-on-ignition-problem) |
SD C4 Sprinter 2007 "turn on ignition" problem. - anagram1928 - 11-17-2016 Hello friend. ![]() I'm having very strange issue with Mercedes Sprinter from 2007 year. I can't connect to the car because it's asking me to turn on the ignition. I'm not having any issues with the C4 itself, today I tested it on Sprinter 2010 year and it connected well, without any problems, also B class from 2012 and ML from 2010. What can be the problem then? Regards.
RE: SD C4 Sprinter 2007 "turn on ignition" problem. - pesona - 11-17-2016 check pin 8 on the vehicle's obd2 if there is a cable or not. RE: SD C4 Sprinter 2007 "turn on ignition" problem. - anagram1928 - 11-17-2016 Thank you very much Pesona for your answer. If other diagnostic equpiment is working fine where else the problem can be? Regards. RE: SD C4 Sprinter 2007 "turn on ignition" problem. - HestonDiag - 11-17-2016 Different diagnostic tools may work in slightly different ways, but for W906 before 2013 facelift, Mr. Pesona's advise is the best place to start. If you are sceptical about that theory, connect your mux to bench power supply and try to connect to W906. If you enter any values for random values for region, fuel type, model type and mileage then try to perform quick test, you will see it will ask you to turn on ignition. Now give power to pin 8 and you will see your computer and multiplexer now believes ignition is on and will try to scan modules. RE: SD C4 Sprinter 2007 "turn on ignition" problem. - anagram1928 - 11-17-2016 Just to be sure. If Sprinter from 2010 year connects right I can assume that it might be the vehicle problem rather than the C4 problem, yes? Thank you guys for your advices. |
