Hello lovely MHHAUTO Users and Staff,
I recently bought a SD Connect Clone of china (it has C5 Design with C4 PCB I think). Anyways, I want to use it with the batteries because I want to use it via WiFi. The reason is simple: It get's really cold here and I want to use the wifi function during Winter so I can sit in the warm office and the car parks next to the window so there is barely any loss in data transfere. I wont do heavy duty coding etc. Just reading faults and diagnostics and research online with the desktop pc.
To take advantage of the WiFi feature, I want to charge it via the OBDII to Mux Cable, like the original MUX does with the Testadapter. (I already have a OBDII Port ordered from eBay that I can solder wires to). Now I want to know how much Volts and Ampers I can send to MUX with a Laptop Power supply or other power supply without damaging the MUX? I want to know the right amount of Volts and Ampers to be precise. Or Which amount of Volts and Amps are okey. I know that most chinese clones are rubbish with the charging circuit but I want to try it out since I already ordered the OBDII Port etc. Would be cool if you could help out!
Can you maybe link me the banana plug's you where talking about earlier or do you just hook up the car battery charger to the cable it self?
