SD Connect MUX Voltage & Amperage through OBDII Port - Printable Version
+---- Thread: SD Connect MUX Voltage & Amperage through OBDII Port (/Thread-SD-Connect-MUX-Voltage-Amperage-through-OBDII-Port)
SD Connect MUX Voltage & Amperage through OBDII Port - MD20 - 01-06-2017
Hello lovely MHHAUTO Users and Staff,
I recently bought a SD Connect Clone of china (it has C5 Design with C4 PCB I think). Anyways, I want to use it with the batteries because I want to use it via WiFi. The reason is simple: It get's really cold here and I want to use the wifi function during Winter so I can sit in the warm office and the car parks next to the window so there is barely any loss in data transfere. I wont do heavy duty coding etc. Just reading faults and diagnostics and research online with the desktop pc.
To take advantage of the WiFi feature, I want to charge it via the OBDII to Mux Cable, like the original MUX does with the Testadapter. (I already have a OBDII Port ordered from eBay that I can solder wires to). Now I want to know how much Volts and Ampers I can send to MUX with a Laptop Power supply or other power supply without damaging the MUX? I want to know the right amount of Volts and Ampers to be precise. Or Which amount of Volts and Amps are okey. I know that most chinese clones are rubbish with the charging circuit but I want to try it out since I already ordered the OBDII Port etc. Would be cool if you could help out!
Thanks Smile
RE: SD Connect MUX Voltage & Amperage through OBDII Port - Anturage - 01-06-2017
Up to 32V 2A
You can readout this info from label on the back of SDConnect
RE: SD Connect MUX Voltage & Amperage through OBDII Port - MD20 - 01-06-2017
Thank you! I thought these labels are just gambled stuff that is most of the time not accurate :/ So anything between 8-32V and Min/Max 2A is just fine as far as I understood right?
With low range voltages about 8-10V it will just startup but not charge batteries.
Original charging adapter has 20v output.
Thanks! That was the answer I was searching for Smile By the way, as far as I understood the OBD2 Pinout, Pin 5 is Ground and Pin 16 is 12v always on am I right? So If I connect Ground to Pin 5 and the 20v power rail of for example a notebook charger to Pin 16 it would startup and also charge the batteries right? Or did I miss one pin/-s?
RE: SD Connect MUX Voltage & Amperage through OBDII Port - Rennbenz - 01-06-2017
I always use the 8-pin banana plug cable at home with a 12V Car charger.
Red - power +12v upto 28v
white - power (optional) => for kl15-ignition test
black - ground
@Rennbenz so you use this cable http://www.obdresource.com/img/p/1394-11073.jpg with the compatible jack inputs right? And I get the Red Power and Black Ground part but do you connect White kl15 for ignition test also to the Red Power rail? Because as far as I know kl15 in the car is 5v (or am I wrong?) Thanks for the insight tho!
(01-06-2017, 09:23 PM)MD20 Wrote: @Rennbenz so you use this cable http://www.obdresource.com/img/p/1394-11073.jpg with the compatible jack inputs right? And I get the Red Power and Black Ground part but do you connect White kl15 for ignition test also to the Red Power rail? Because as far as I know kl15 in the car is 5v (or am I wrong?) Thanks for the insight tho!
Yes, this is the right cable.
To recharge you only need the black (-) and red (+) cables.
Thank you verry much bro! Helped me out really much Smile If I could press the Thanks button more then once I Would've done it Tongue Can you maybe link me the banana plug's you where talking about earlier or do you just hook up the car battery charger to the cable it self?
