dxdroid
Location OfflineJunior Member
Thanks Given: 75
Thanks Received: 41 (22 Posts)
143
35
10-23-2016, 03:10 PM
Hello Everyone,
I have a quick question to you guys. Can you explain to me one thing. I know there is two types of SCN coding: Online and Offline. I have read that on older version of software SCN offline coding is available where on the neweset one it is not. My dumb question is, if I will have Vediamo software etc. does this let me to perform SCN Coding?
340
Thanks Given: 119
Thanks Received: 2494 (1232 Posts)
2,415
18
Difference between online and offline SCN is in method how DAS receive SCN string from Daimler.
Offline - by Fax or email with man help
Online - by Internet communication without man help
Offline method currently is not supported by Daimler
That's it
- SW Seed\key VGS\MED\IC virgin\hard coding Carplay HU5s1 HU5es2 any fw
- HW Genuine XentryConnect-SDConnect-eCom sale\repair\parts\setu
dxdroid
Thanks Given: 75
143
35
So even using Vediamo software you cannot perform SCN Coding?
340
Thanks Given: 119
2,415
18
SCN is process of writing bit strings to one or several ECUs
If you have this string or able to calculate it you can use Vediamo.
If you don't have string you have to use Xentry to download it from Daimler.
dxdroid
Thanks Given: 75
143
35
Last dumb question. From my understanding is that each ECU has its own calculated string. Is that right? I presume for now there is no tools that can calculate these types of strings and you have use Daimler websites to get them.
dxdroid
Thanks Given: 75
143
35
So all the frimware files for ECU's are downloading live from the server when coding is performed. Would you be able to tell me so for what can you use Vediamo software with DB of frimwares
340
Thanks Given: 119
2,415
18
SCN is not file. It is string.
Coding is writing string to ECU eeprom.
Xentry does not allow you input your own string and get it from Daimler.
Vediamo does not communicate with Daimler and let you enter what you want.
dxdroid
Thanks Given: 75
143
35
So this means that if you will get Vediamo with the Database you will be able to do coding on ECU?
