SD Offline SCN Coding - Question - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: SD Offline SCN Coding - Question (/Thread-SD-Offline-SCN-Coding-Question) Pages:
SD Offline SCN Coding - Question - dxdroid - 10-23-2016 Hello Everyone, I have a quick question to you guys. Can you explain to me one thing. I know there is two types of SCN coding: Online and Offline. I have read that on older version of software SCN offline coding is available where on the neweset one it is not. My dumb question is, if I will have Vediamo software etc. does this let me to perform SCN Coding? RE: SD Offline SCN Coding - Question - Anturage - 10-23-2016 Difference between online and offline SCN is in method how DAS receive SCN string from Daimler. Offline - by Fax or email with man help Online - by Internet communication without man help Offline method currently is not supported by Daimler That's it RE: SD Offline SCN Coding - Question - dxdroid - 10-23-2016 So even using Vediamo software you cannot perform SCN Coding? RE: SD Offline SCN Coding - Question - Anturage - 10-23-2016 SCN is process of writing bit strings to one or several ECUs If you have this string or able to calculate it you can use Vediamo. If you don't have string you have to use Xentry to download it from Daimler. RE: SD Offline SCN Coding - Question - dxdroid - 10-23-2016 Last dumb question. From my understanding is that each ECU has its own calculated string. Is that right? I presume for now there is no tools that can calculate these types of strings and you have use Daimler websites to get them. RE: SD Offline SCN Coding - Question - Anturage - 10-23-2016 (10-23-2016, 04:03 PM)dxdroid Wrote: From my understanding is that each ECU has its own calculated string.Yes. Many ECUs have more than one string. String could be different on same ECU with different software version. (10-23-2016, 04:03 PM)dxdroid Wrote: I presume for now there is no tools that can calculate these types of strings and you have use Daimler websites to get them.Yes. There is no universal tool for any ECU with any variant. And sure there is no Daimler website with coding. Xentry perform SCN coding without websites by direct communication with server. RE: SD Offline SCN Coding - Question - dxdroid - 10-23-2016 So all the frimware files for ECU's are downloading live from the server when coding is performed. Would you be able to tell me so for what can you use Vediamo software with DB of frimwares RE: SD Offline SCN Coding - Question - Anturage - 10-23-2016 SCN is not file. It is string. Coding is writing string to ECU eeprom. Xentry does not allow you input your own string and get it from Daimler. Vediamo does not communicate with Daimler and let you enter what you want. RE: SD Offline SCN Coding - Question - dxdroid - 10-23-2016 So this means that if you will get Vediamo with the Database you will be able to do coding on ECU? |
