  • 14 Vote(s) - 2.64 Average
SD connect lan connection problem
Hi, suddenly yesterday my sdconnect lost wifi and cable connection and now i can't connect by lan (ni wireless tampoco). No connection, it's not a ip problem, i've tested some different lan cables and no way.
I have this images in screen.
Any way to factory reset or any idea?
Press wrench button twice, you will get delete configuration and follow instructions on the screen
instructions are press "wrench" and "ok" for 3 sec. Then beep and goes to main screen (1st image).
I think it don't delete the config because it retains the same number.
You need to update your C4. that's all i think. Your OSD is old to work with newest Xentry Version.
CSD 0.00..., maybe blocked?
(10-19-2016, 10:02 PM)anonimo Wrote: You need to update your C4. that's all i think. Your OSD is old to work with newest Xentry Version.
Not possible to connect by lan, I can't see it in SDconnect toolkit. Lan icon in system tray with "X"
Firmware lost.
You have to establish LAN connection and reflash it with Toolkit.
Without LAN you will do nothing with this unit.
  • SW Seed\key VGS\MED\IC virgin\hard coding Carplay HU5s1 HU5es2 any fw
  • HW Genuine XentryConnect-SDConnect-eCom sale\repair\parts\setu
a pic change?
have you ever worked with this C4? witch Xentry Version are you using?
I was working with this C4 in a laptop with Xentry 12.2014. But somebody in the workshop connect it to an official and original "MB SD Tablet Siemens" with Xentry update to date, they have the same wireless ip range. I think the original equipment try to update firmware and locked it for "chinese scrap"
I think these were the circumstances, but not sure
