SD connect lan connection problem - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: SD connect lan connection problem (/Thread-SD-connect-lan-connection-problem) Pages:
SD connect lan connection problem - salbutamol - 10-19-2016 Hi, suddenly yesterday my sdconnect lost wifi and cable connection and now i can't connect by lan (ni wireless tampoco). No connection, it's not a ip problem, i've tested some different lan cables and no way. I have this images in screen. [attachment=150254] [attachment=150255] [attachment=150256] [attachment=150257] [attachment=150258] Any way to factory reset or any idea? Thanks RE: SD connect lan connection problem - efka - 10-19-2016 Press wrench button twice, you will get delete configuration and follow instructions on the screen RE: SD connect lan connection problem - salbutamol - 10-19-2016 instructions are press "wrench" and "ok" for 3 sec. Then beep and goes to main screen (1st image). I think it don't delete the config because it retains the same number. RE: SD connect lan connection problem - anonimo - 10-19-2016 You need to update your C4. that's all i think. Your OSD is old to work with newest Xentry Version. RE: SD connect lan connection problem - salbutamol - 10-19-2016 CSD 0.00..., maybe blocked? (10-19-2016, 10:02 PM)anonimo Wrote: You need to update your C4. that's all i think. Your OSD is old to work with newest Xentry Version.Not possible to connect by lan, I can't see it in SDconnect toolkit. Lan icon in system tray with "X" RE: SD connect lan connection problem - Anturage - 10-19-2016 Firmware lost. You have to establish LAN connection and reflash it with Toolkit. Without LAN you will do nothing with this unit. RE: SD connect lan connection problem - salbutamol - 10-19-2016 a pic change? RE: SD connect lan connection problem - anonimo - 10-19-2016 have you ever worked with this C4? witch Xentry Version are you using? RE: SD connect lan connection problem - salbutamol - 10-19-2016 I was working with this C4 in a laptop with Xentry 12.2014. But somebody in the workshop connect it to an official and original "MB SD Tablet Siemens" with Xentry update to date, they have the same wireless ip range. I think the original equipment try to update firmware and locked it for "chinese scrap" I think these were the circumstances, but not sure |
