  • 19 Vote(s) - 3.32 Average
SDconnect serial 101044 works with Xentry 2016 Firmware ?
does anyone know whether a sdconnect with 101044 serial and OS 2.3 and CSD 2.8 can be updated to work with Xentry 2016 Version ?
Or will it get blocked ?
Thanks a lot in advance for your much appreciated reply
First you need blacklist fix for your Xentry version and yes can be updated and used with Xentry version 2016.
Thanks given by: Rocinante , smartcard , daxxer , sam pro
works with 09.2016
PLEAS "thanks" [Image: thanks.jpg] and "reputation" [Image: rate.jpg]
Thanks given by: smartcard , daxxer , sam pro
Thanks a lot for the reply, for example i use 12.2015 on win7, i just download blacklist fix for 12.2015 open shell and apply it and rename folders in sdconnect toolkit ? Thats all ?
Regards
(10-18-2016, 10:39 PM)laco210 Wrote: First you need blacklist fix for your Xentry version and yes can be updated and used with Xentry version 2016.
(10-18-2016, 11:15 PM)smartcard Wrote: Thanks a lot for the reply, for example i use 12.2015 on win7, i just download blacklist fix for 12.2015 open shell and apply it and rename folders in sdconnect toolkit ? Thats all ?
Regards
Yes! But you need to update the firmware of your mux OS 2.3 CSD 2.11
If I helped do not forget to press thanks and reputation buttonHandshake
No problem updating firmware in clones
Thanks given by: sam pro , obdshop
I tried to update but i get UHD 780 Error? It says SDconnect Hardware defective... ???
Pls help. Thanks
(11-10-2016, 12:09 AM)smartcard Wrote: I tried to update but i get UHD 780 Error? It says SDconnect Hardware defective... ???
Pls help. Thanks
mean your sdconnect is not good clone.........now u need go back your olf firmware 2.3 and the best may be u can go 2.10 if u can find the this firmware or u need go back old 2.3 & 2.8.........because u might not a good clone board missing a lot ic and most is problem is wifi cause error a lot........if like my post help.......Big Grinplease press button thanks & rep me feel good 049
Thanks given by: John Lee
Pls help. Thanks
Poor quality clone Fing20 . You may try older firmware from older version of Xentry. ( Listen you need Toolkit folders be originals). The bad news is you will not be able to use any latest Xentry version Sadsmile
