SDconnect serial 101044 works with Xentry 2016 Firmware ? - Printable Version
+---- Thread: SDconnect serial 101044 works with Xentry 2016 Firmware ? (/Thread-SDconnect-serial-101044-works-with-Xentry-2016-Firmware)
SDconnect serial 101044 works with Xentry 2016 Firmware ? - smartcard - 10-18-2016
Hi,
does anyone know whether a sdconnect with 101044 serial and OS 2.3 and CSD 2.8 can be updated to work with Xentry 2016 Version ?
Or will it get blocked ?
Thanks a lot in advance for your much appreciated reply
RE: SDconnect serial 101044 works with Xentry 2016 Firmware ? - laco210 - 10-18-2016
First you need blacklist fix for your Xentry version and yes can be updated and used with Xentry version 2016.
RE: SDconnect serial 101044 works with Xentry 2016 Firmware ? - luki03 - 10-18-2016
works with 09.2016
RE: SDconnect serial 101044 works with Xentry 2016 Firmware ? - smartcard - 10-18-2016
Thanks a lot for the reply, for example i use 12.2015 on win7, i just download blacklist fix for 12.2015 open shell and apply it and rename folders in sdconnect toolkit ? Thats all ?
Regards
(10-18-2016, 10:39 PM)laco210 Wrote: First you need blacklist fix for your Xentry version and yes can be updated and used with Xentry version 2016.
RE: SDconnect serial 101044 works with Xentry 2016 Firmware ? - graphix - 10-18-2016
(10-18-2016, 11:15 PM)smartcard Wrote: Thanks a lot for the reply, for example i use 12.2015 on win7, i just download blacklist fix for 12.2015 open shell and apply it and rename folders in sdconnect toolkit ? Thats all ?
Regards
Yes! But you need to update the firmware of your mux OS 2.3 CSD 2.11
RE: SDconnect serial 101044 works with Xentry 2016 Firmware ? - salbutamol - 10-19-2016
No problem updating firmware in clones
RE: SDconnect serial 101044 works with Xentry 2016 Firmware ? - smartcard - 11-10-2016
I tried to update but i get UHD 780 Error? It says SDconnect Hardware defective... ???
Pls help. Thanks
RE: SDconnect serial 101044 works with Xentry 2016 Firmware ? - thanh1974 - 12-26-2016
(11-10-2016, 12:09 AM)smartcard Wrote: I tried to update but i get UHD 780 Error? It says SDconnect Hardware defective... ???
Pls help. Thanks
mean your sdconnect is not good clone.........now u need go back your olf firmware 2.3 and the best may be u can go 2.10 if u can find the this firmware or u need go back old 2.3 & 2.8.........because u might not a good clone board missing a lot ic and most is problem is wifi cause error a lot........if like my post help.......Big Grinplease press button thanks & rep me feel good 049
RE: SDconnect serial 101044 works with Xentry 2016 Firmware ? - ICEman-x - 12-26-2016
Pls help. Thanks
Poor quality clone Fing20 . You may try older firmware from older version of Xentry. ( Listen you need Toolkit folders be originals). The bad news is you will not be able to use any latest Xentry version Sadsmile
