Thanks Given: 126
Thanks Received: 43 (24 Posts)
222
75
07-28-2020, 03:10 PM
(This post was last modified: 07-29-2020, 05:54 PM by maverickqwe.)
HI I have a vauxhall Corsa d 2009 I am unable to connect to BCM PAS ABS ECM. No start situation. Showing F In dash display ( Vehicle was ok before it was not used for two days )
I have bypasssed PAS and ABS on can lines still no connection. I have checked can lines from diagnostic connector to BCM through all units to ECM all have good continuity. Dash lights as usually only fuel gauge showing empty. Tried swapping out BCM (only difference is spanner light flashing )with a reset unit still the same dash and ECM swapped still the same. All lights central locking ect working. Can connect to radio and display, air bag module and dash ok. Dash gives code for incorrect data from BCM
Anyone have any ideas please?
You have to know how something works before you can fix it !!
1,750
Thanks Given: 5694
Thanks Received: 6560 (2578 Posts)
4,401
21
reprogram/pair the bcm with car
common fault if battery drained
bcm looses all info
Please be polite and click THANKS if my post is helpful...
Thanks Given: 126
222
75
How do I reprogram BCM if I can't communicate with it via diagnostic port, would it have to be via a vauxhall dealer ?
41
Thanks Given: 182
Thanks Received: 209 (117 Posts)
259
13
m8, it looks like you have power issue, have you checked your maxi fuses?
Thanks Given: 126
222
75
Yes maxi fuses ok and all other fuses checked can't understand no comms with BCM as all systems seem to operate and it has power, power to ECM also !
41
Thanks Given: 182
259
13
07-29-2020, 02:41 AM
(This post was last modified: 07-29-2020, 02:46 AM by Pemaxt.)
Then you may have fault module somewhere which can lead to can bus network issue.
Test can bus with oscilloscope and upload photo of the signal pattern.
Also pull out wiring diagram and check can bus wires from the obd port to the first module.
If for example can wires go to ABS module first and then to the rest of the modules, you may have communication with ABS, but not with other modules if there is wiring issue after the ABS.
Thanks Given: 126
222
75
Thanks for all your help now solved units may have live and earths, but the (ignition main circuits relay 1) in engine main fuse box was the problem, stops can communiction between modules think it powers the BCM seperatly from the main power feed in !!
709
Thanks Given: 2326
Thanks Received: 2447 (816 Posts)
2,014
125
I have a corsa d here that has exactly the same symptoms and things,but relays in fuse box are ok tested,fusebox opened,tried already abs/eps/engine ecu/fusebox/ checked wires.what the hell is this faultttttttttttttt
If i Helped,please press thanks and +rep buttons
