21
Thanks Given: 259
Thanks Received: 125 (80 Posts)
389
104
Hi Guys. I have a problem with DelcoTDS and Techline Connect. I purchased a VIN. No problem. Do the programming. No problem. This is it in the morning. On the afternoon i want to sniff around. This its the first time i use this kind of programing. Again enter in the ACdelco TDS web and i want to click on the VIN i purchased. When i do the click. New TAB open and i get the following error. "Access Unauthorized with destination system" attacht the screenshot.
Anybody can help me?.
https://imgur.com/a/Mpmihmu
Proton VPN
Scanmatik 2 Clone.
If my help its useful, than press THANKS & REPUTATION BUTTON!!!!!
1,225
Thanks Given: 249
Thanks Received: 2238 (930 Posts)
2,448
38
(02-26-2025, 04:45 AM)JuamPa Wrote: Hi Guys. I have a problem with DelcoTDS and Techline Connect. I purchased a VIN. No problem. Do the programming. No problem. This is it in the morning. On the afternoon i want to sniff around. This its the first time i use this kind of programing. Again enter in the ACdelco TDS web and i want to click on the VIN i purchased. When i do the click. New TAB open and i get the following error. "Access Unauthorized with destination system" attacht the screenshot.
![[Image: Mpmihmu]](https://imgur.com/a/Mpmihmu)
Proton VPN
Scanmatik 2 Clone.
your account is blocked
mercedes retrofit,coding,programming,AMG menu,CARPLAY
FORD (remote coding programming) help
opel Coding programming help
JLR services
21
Thanks Given: 259
389
104
(02-26-2025, 04:55 AM)globalcartuning Wrote: (02-26-2025, 04:45 AM)JuamPa Wrote: Hi Guys. I have a problem with DelcoTDS and Techline Connect. I purchased a VIN. No problem. Do the programming. No problem. This is it in the morning. On the afternoon i want to sniff around. This its the first time i use this kind of programing. Again enter in the ACdelco TDS web and i want to click on the VIN i purchased. When i do the click. New TAB open and i get the following error. "Access Unauthorized with destination system" attacht the screenshot.
Proton VPN
Scanmatik 2 Clone.
Why?
1,801
Thanks Given: 67
Thanks Received: 3285 (425 Posts)
658
39
02-26-2025, 05:17 AM
(This post was last modified: 02-26-2025, 05:18 AM by ZooperDooper.)
(02-26-2025, 05:06 AM)JuamPa Wrote: (02-26-2025, 04:55 AM)globalcartuning Wrote: (02-26-2025, 04:45 AM)JuamPa Wrote: Hi Guys. I have a problem with DelcoTDS and Techline Connect. I purchased a VIN. No problem. Do the programming. No problem. This is it in the morning. On the afternoon i want to sniff around. This its the first time i use this kind of programing. Again enter in the ACdelco TDS web and i want to click on the VIN i purchased. When i do the click. New TAB open and i get the following error. "Access Unauthorized with destination system" attacht the screenshot.
Proton VPN
Scanmatik 2 Clone.
Why?
Why? - Because they have banned all clone devices and only genuine interfaces are allowed. If you contact them they will unblock it for you once and once only so get a genuine j2534 device or you will not be using Techline Connect.
Now having said that there is a way to change the serial number on clone MDI devices that apparently works (I have not tried)
I uses a genuine Bosch MDI2 as can't afford to be blocked and want to keep using it so you have to ask yourself the big question do I want to use TLC or save money on non genuine interfaces? - the answer to that question will decide your fate
21
Thanks Given: 259
389
104
(02-26-2025, 05:17 AM)ZooperDooper Wrote: (02-26-2025, 05:06 AM)JuamPa Wrote: (02-26-2025, 04:55 AM)globalcartuning Wrote: (02-26-2025, 04:45 AM)JuamPa Wrote: Hi Guys. I have a problem with DelcoTDS and Techline Connect. I purchased a VIN. No problem. Do the programming. No problem. This is it in the morning. On the afternoon i want to sniff around. This its the first time i use this kind of programing. Again enter in the ACdelco TDS web and i want to click on the VIN i purchased. When i do the click. New TAB open and i get the following error. "Access Unauthorized with destination system" attacht the screenshot.
Proton VPN
Scanmatik 2 Clone.
Why?
Thanks man. Very appreciated for the response. Ill buy a Geniune one. Autel or TopOdon its supportted?.
1,801
Thanks Given: 67
658
39
(02-26-2025, 05:50 AM)JuamPa Wrote: (02-26-2025, 05:17 AM)ZooperDooper Wrote: (02-26-2025, 05:06 AM)JuamPa Wrote: (02-26-2025, 04:55 AM)globalcartuning Wrote: (02-26-2025, 04:45 AM)JuamPa Wrote: Hi Guys. I have a problem with DelcoTDS and Techline Connect. I purchased a VIN. No problem. Do the programming. No problem. This is it in the morning. On the afternoon i want to sniff around. This its the first time i use this kind of programing. Again enter in the ACdelco TDS web and i want to click on the VIN i purchased. When i do the click. New TAB open and i get the following error. "Access Unauthorized with destination system" attacht the screenshot.
Proton VPN
Scanmatik 2 Clone.
Why?
Genuine Autel J2534 work and most do anyway but if it is a clone then it won't take long to get blocked so just make sure you buy from a reputable seller which is getting increasingly difficult to do as everyone wants our hard earned.
1,801
Thanks Given: 67
658
39
(03-01-2025, 12:11 AM)SlimJim Wrote: (02-26-2025, 06:26 AM)ZooperDooper Wrote: (02-26-2025, 05:50 AM)JuamPa Wrote: (02-26-2025, 05:17 AM)ZooperDooper Wrote: (02-26-2025, 05:06 AM)JuamPa Wrote: Why?
ZooperDooper this is very good information and very interesting to me as I'm new to these systems and would like to be able to maintain my own vehicles. With your experience how do you feel about the VXDIAG VCX FD. I own a Ford F150 and a Cadillac CTS. Your helpful information would be very much appreciated. Thanks and you have my respect
I can't comment first hand experience but I have been told that the VXDiag interfaces are banned on SPS Techline Connnect and will get your account locked.
I was under the impression that J2534 interfaces were all good but have since found out they are banning certain ones made in China & Russia as they send information about your Techline account back to the hackers so you need to play it safe if you want to keep your account.
So you might need to contact GM on that one as no point buying something that is not going to work or will get you blocked.
Apofis
Location OfflineJunior Member
21
Thanks Given: 30
Thanks Received: 47 (28 Posts)
106
autel J2534 works fine with sps
IF I HELP, PLEASE PRESS REPUTATION+1 AND THANKS
