14
Thanks Given: 1015
Thanks Received: 71 (39 Posts)
379
78
Hi....sorry if already been covered. Got a 450 with replaced donor engine ecu and wanting to programme into car. I think all I need to do is relearn the keys again. Have xentry and das........
Is this all I need and procedure please?
42
Thanks Given: 132
Thanks Received: 214 (115 Posts)
574
30
If you need help. Connect me by teamviwer I try to help.
Skype: googly007
227
Thanks Given: 1490
Thanks Received: 1205 (393 Posts)
627
19
06-11-2016, 08:47 PM
(This post was last modified: 06-11-2016, 08:48 PM by HestonDiag.)
First thing you will need TAN code generator. I believe there are two on this forum available for free.
Also if you are using recent Xentry/DAS, (I think after 2012), you need to find the patch to allow the old style TAN codes to work - the patch I think is just older version of csdsmart.dll which is also available on this forum for free if you search.
This will work for Smart cars that work in DAS, but not for newer Smart's that need Xentry.
Thanks Given: 117
Thanks Received: 115 (48 Posts)
233
24
If you have old ECU, just clone the flash in the ECUs, it's probably 28f400 or 29f400 flash
Sent from my SM-A300FU using Tapatalk
14
Thanks Given: 1015
379
78
Thanks to everyone.
You were all correct. I downloaded a patch from here and copied it into F-DAS-SMART and this elimininated the request code. Then just follow on screen instructions in MEG to learn immobiliser again.
Thanks all.
