Smart 451 paddle shif coding
Hello, I'm new here,
My situation is as follows:
I have a 451 with softshift and manual mode. I bought a steering wheel with paddle shifters (I already modified the wiring under the steering wheel, checking the correct ohms and cable positions; I saw how to do it on Evilution) and I would like to activate and program the steering wheel.
I've been researching your posts and found Expat_Mat's post (https://mhhauto.com/Thread-Smart-451-Pad...activation) to activate it via Vediamo (since I couldn't do it through Xentry).
I read and reread the PDF and tried to follow it, but I'm a novice in this area. I managed to access the described menus, but I don't know how to proceed.
1. I want to activate the paddles.
2. I want to program the initial sequence: F2 242 Softouch – Paddles – Automatic at start
For me, it's enough that the paddles are working to see if they are functional.
Thank you in advance for your availability, and I would appreciate any help.
Xentry is easiest way to do it
(06-14-2026, 01:39 AM)macbut999 Wrote: Xentry is easiest way to do it
i have a xentry 03/2026 with openport 2.0,
i can enter in menu n15/6, in control unit adaptations, but doent appear option to do it.
i activate paddle shifters via vediamo seeing pdf, but paddles doesnt work.
problem resolved!!!
i just search files in forum to can use offline programing, install new ones, an xentry programed my car.
06-09-2026, 03:37 AM
06-08-2026, 11:24 AM
06-05-2026, 01:48 PM
