Smart 451 paddle shif coding - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: Smart 451 paddle shif coding (/Thread-Smart-451-paddle-shif-coding) |
Smart 451 paddle shif coding - tviper - 06-13-2026 Hello, I'm new here, My situation is as follows: I have a 451 with softshift and manual mode. I bought a steering wheel with paddle shifters (I already modified the wiring under the steering wheel, checking the correct ohms and cable positions; I saw how to do it on Evilution) and I would like to activate and program the steering wheel. I've been researching your posts and found Expat_Mat's post (https://mhhauto.com/Thread-Smart-451-Paddleshift-activation) to activate it via Vediamo (since I couldn't do it through Xentry). I read and reread the PDF and tried to follow it, but I'm a novice in this area. I managed to access the described menus, but I don't know how to proceed. 1. I want to activate the paddles. 2. I want to program the initial sequence: F2 242 Softouch – Paddles – Automatic at start For me, it's enough that the paddles are working to see if they are functional. Thank you in advance for your availability, and I would appreciate any help. RE: Smart 451 paddle shif coding - macbut999 - 06-14-2026 Xentry is easiest way to do it RE: Smart 451 paddle shif coding - tviper - 06-14-2026 (06-14-2026, 01:39 AM)macbut999 Wrote: Xentry is easiest way to do it i have a xentry 03/2026 with openport 2.0, i can enter in menu n15/6, in control unit adaptations, but doent appear option to do it. i activate paddle shifters via vediamo seeing pdf, but paddles doesnt work. RE: Smart 451 paddle shif coding - tviper - 06-14-2026 (06-14-2026, 05:00 PM)tviper Wrote:(06-14-2026, 01:39 AM)macbut999 Wrote: Xentry is easiest way to do it problem resolved!!! i just search files in forum to can use offline programing, install new ones, an xentry programed my car. |
