  • 21 Vote(s) - 3.33 Average
Superscan PSA
19
i have renault com and it was possible to add PSA code from first post.
here is renault if somebody needs.
regards
.txt
Read me.txt
375
467 bytes
20
PSA and Renault devices have different serial numbers.
Тhe codes are specific for each serial number.
Code for PSA serial is not accepted from Renault device and vice versa.
(11-15-2018, 10:06 PM)tk500 Wrote: PSA and Renault devices have different serial numbers.
i did no test on car, but after entering psa code the both additional trademarks appeaered and could be choosed.
i think this is not correct,as when you buy the tool,they give you just a code for activation of the brand.
So if you have two codes,you can activate two brands.
I dont know if it is this easy but it is worth a try.
If i Helped,please press thanks and +rep buttons
Hi. Not work. The device is coded for PSA i have all key and is active in software, but not work inside the probe is key code for PSA or Renault. For all to work is need other Probe. SUPERSCAN 3. Not find to buy.
https://mhhauto.com/Thread-Dec-Superscan3
I have both types. What I wrote is the result of tests.
I just tested installing renault and also adding the code from psa and it works in the same device,no need for any changes.
Tested in clio 2ph3 and citroen c3 1st gen.
Do not work at all other.
Please post some pictures.
What code you enter for PSA ? ( 0E9E46DA )
Thanks given by: Stelaras , starline , wowa557
27
So does it work or not?! I have PSA COM and it has very simple interface and works great. I am thinking to buy REnault adapter?!
So does it work on same device or not?!
When I have time I will try it on my device and post results.
Peugeot
06-11-2026, 04:34 PM
04-06-2026, 09:04 PM
02-27-2026, 07:42 PM
