[email protected]
Superscan PSA
29
05-16-2019, 05:01 PM
I have renault and psa device, they work with same softver on same PC, but what you need to do each time you switch makes.
1. go to bluetooth menu in windows, delete AutoScan&Programming
2. Add device.. add again bluetooth adapter of make you wanna use pass is 1234
3. Open SuperScan Manager > Configure > SuperScan > Autodetect
and then it works
and then it works
Thanks given by: zuppe9000
31
10-04-2019, 08:41 PM
What software would you like mate??
If i Helped,please press thanks and +rep buttons
32
10-07-2019, 01:23 AM
Some version of Superscan PSA.I have version 10.2 but it doesn't recognize Bluetooth channel. I would like to try some other version.It's strange since my Bluetooth can see the device but the Superscan can't see on what channel is it.
33
10-07-2019, 04:12 PM
You have other problem, because it interface is paired with PC it is IMPOSSIBLE that any windows program don't see it. Of course you can write own program that don't see ant BT device but we talk about legitimate programs.
I am sure you have good program but problem is in your BT module. Try to update drivers, or use USB stick instead.
All the best,
Jaky
All the best,
Jaky
If my post helped you please use
and
and
34
10-07-2019, 07:40 PM
I have USB Bluetooth V4 on my laptop,and I have installed drivers that came with him.After he detects (entered pair cod and accepted) PSA COM in USB Bluetooth settings there are only 2 outgoing channels,no incoming from the PSA COM ( also BT light on PSA COM is off).How come PSA COM is detected and paired but no incoming channel from it?
35
10-08-2019, 12:25 PM
Maybe BT on PSA is defective, but I think that drivers can be problem. Pair from Windows not Superscan. Try on other computer and see if any differences.
All the best,
Jaky
All the best,
Jaky
and
and
36
12-17-2019, 12:28 AM
I have Superscan 2 and software 10.2.3. I can update to 10.2.6 with the keys I have. I need to move to another laptop but I cannot
find anywhere to download software. Anybody have a copy available ?
