  • 13 Vote(s) - 2.54 Average
Support thread for FullFixbySamik paid version
451
I installed the full paid version I used the Fullfix for Xentry and Truck v.9.1.1of Xentry Openshell 06.2025 According to the instructions, I let the addon installation run. I used SDC4-VCI Switcher, the VCI icon disappeared
I entered the address 172.29.127.xxx according to the instructions. C4 connected by cable.
The sdconnect icons respond, I can also see the C4 number. After opening the administration, the tables are empty.
config assist does not offer the SDC4 option
Can I ask for advice on how to fix the problem?
Solved: This morning I clicked on SD connect and it was complete in my native language - I don't understand it and I don't even know where the problem was
Thanks given by: hgmdiag
452
For quite a long time I’ve been having problems with certificates.
At the beginning of the year, I applied the fix on two tablets: one with an SM2 PassThru and the other with a C4 (M6+). Shortly after the installation, I diagnosed a 2025 Vito W447. The medal was yellow. Later, I worked on two more W447s, but the C4 would not connect and only the SM2 worked.
Recently, a CLA C118 came in. The C4 showed a red medal with error C003 – no authorization/permissions. I switched to the SM2, read the fault codes, performed a quick test, and everything worked fine with a yellow medal.
About 2–3 hours later, the certificates on the SM2 were gone as well, and the medal turned red. I tried to refresh the certificates, but it was not possible.
Does anyone have any idea why these certificates keep getting corrupted or expiring? How can I fix this? It’s really frustrating that after only a few connections to vehicles that I was previously able to diagnose, I suddenly can’t connect anymore.
Today I already installed a fresh system for the SM2 and applied Fix V9, but I’d appreciate any advice on where I might be making a mistake that causes these certificates to stop working. Any suggestions would be greatly appreciated.
[Image: LXKjCHhH]
[Image: IMG-0124.jpg]
W220 Long 400 CDI  Muscle
There's no lifetime certificate!
All certificates have expiration date.
When you install fix, fix install one certificate with X expiration date. When coming tgat X day, certificate deleting automatically, because it's no longer valid and won't work anymore!
Fix didn't give you lifetime certificate, i didn't promise anybody lifetime certificate.
But anyway, i am trying to always update it.
If certificate expires, you can find some new here in forum, use search.
Or you can just run fix one more time (if HWID didn't changed, it won't ans activating key) and select only install certificate option.
(06-16-2026, 03:18 AM)Sam!k Wrote: There's no lifetime certificate!
I try instal only centrificat but not working. in early version trying C003 fix from forum this same. Cerificat valid date is 9999-12-31
(06-16-2026, 03:22 AM)chlystek Wrote: I try instal only centrificat but not working. in early version trying C003 fix from forum this same. Cerificat valid date is 9999-12-31
There's no unlimited certificate!
Why you think i delete it from new versions?
Right, because it was wrong thing!
You don't need anything accept fix and valid certificate un system! All other fix's, patches and anything are useless and can brake working system!
P.S. You need read more about certificate based cars, need to understand how it's working, how EZS checking certificate validation and etc.
(02-27-2026, 05:23 PM)Sam!k Wrote:
(02-27-2026, 05:32 AM)MrIgor Wrote: Hey,
I have the full fix 8.4, i got XDOS 6.25 working, vediamo working, how do I activate dts monaco 9? I see a license.bin in the activators folder, but it mentions to change mac address, would that affect xentry or is that another fix for vediamo? Also anything special I have to do in monaco/vediamo to work with original c4?
Why you think DTS 9 is not already activated?
Maybe it's already activated?
When you run it, you see some activation requests?
Or you see working program?
Or you even didn't run it?
Sure, you have to configure all programs to working with your adapter but it's not fix's job in your case, so just make search in forum.
Hey,
Alright so yes i get an error message when i open the app, stating "The license file is not compatible with the selected characteristics 0x000000 eSystem_License_error" Using original C4, xentry works, vediamo works but not monaco(Used the full fix to install monaco)
(06-23-2026, 04:37 PM)TodTheBeast Wrote: Thank you for the activation! I'm just struggling with the SDFlash at the moment. Is there any way to load all the files together? Thanks for the help
No
(06-04-2026, 11:23 PM)Rocinante Wrote:
(06-04-2026, 07:24 PM)hgmdiag Wrote: HELLO BOSS
THIS IS MY 2ND COMPUTER, for C4.
TWO DIFFERENT C4 , 2 DIFFERENT LAPTOP .
XENTRY VERSION 04/2026 .
BUT WINDOWS DOESNT SEE THE C4 AND DOESNT CONNECT AT ALL !!?
CAN YOU PLEASE HELP . I AM REALLY STUCK HERE WITH CUSTOMER .
I AM SO GRATEFUL IN ADVANCE FOR THE HELP .
And yes, FIREWALL IS ON. IP IS CONFIGURED CORRECTLY. But still no connection at all !!
You need the paid version to get SDConnect to work, its not included in the free version
no way , !! did come up with this solution on your own or you got some consultant from ALIENS too !!!? jeezz!
I am not sure, shat you means with windows doesn't see SDConnect but if you means that Toolkit doesn't see SDConnect, so for that even no need config IP address!
Toolkit should see SDConnect if:
1. Ethernet adapter is working, driver installed.
2. LAN cable is working, connected with laptop and SDConnect.
3. SDConnect is working, connected with laptop and power.
4. 12-24v connected to SDConnect from obd cable side.
5. In system nothing blocking connection, it can be firewall, antivirus, favourite game or i don't know what else can be.
Look for your problem in this 5 ways.
Mate, I have been doing this for 12 years, always clean fresh windows, defender off, firewall ticked and UNTICKED (after you said let firewall ask for connection)... its not my first time.
as i said one of my guys also has C6, but not even C6 connects (as you know C6 connects through USB)!  but today one of these guys after 1 month turned on the computer and C4 shows up and connects  !! on its own , out of nowhere !
Just a question, how important is WIFI, LAN DRIVER in this ?
somebody told me you have to use old 2015 drivers .  is it true ?
i had another guy , C4 and VCX , none working . He also has Lenovo laptop . i only managed to make his VCX WORK THROUGH WIFI connection only.
is there anything to do with Lenovo Lan driver ? or my Windows USB? i use Windows 10 Pro 2004 and then update. then install xentry ...
OR ITS SOMETHING CHANGED WITH NEW XENTRY ? if you promise you won't share it with your customers, I am willing to give you my 12.2025 or 2026 link, so you can test it. (the reason is i got it direct from daimler through a friend working there so.... if you know what i mean )
i am thinking I am cursed recently !!
Very rude!
So if you working 12 years with that, i don't think i can help you, don't work so long time.
As you said, there's so strange things in your clients laptops, i don't think anybody can explain that except them!
About VCX or USB drives, never had problems, always without problems.
Yes, i read something about wi-fi drivers, for working with SDConnect, somebody said, that they should be some old.
